I think I got the wrong Toda header....
Old Jun 27, 2002 | 09:23 PM
CStyles45's Avatar
Default I think I got the wrong Toda header....
Hey everyone. Good news and bad news for the day. Good news, I got in my Toda header for my ITR today. wOOt wOOt! But.....bad news....we went to install it at my local Acura dealership when it turned out that it didn't fit on the car!! Two things just weren't lining up with it. One, we were able to get the outer two bolts that go from the header to the head in okay, but when we tried to put back in the other bolts, they were a few millimeters too high, which means they wouldn't go in at all. Second, the part where the colllector connects to the cat...it's connected by two bolts. The two bolts on the factory cat lay horizontal while the bolts on the Toda header layed at about a 45* angle. I'm assuming that I got the wrong header. I think I accidently got one for a B16A/B instead of a B18C, HOPEFULLY this is the case. Anyone think that's what happened or is that somehow the right one for my ITR? Another quick question...was the header supposed to come with new gaskets or am I supposed to use my factory ones? I'm going to give Leo a call tomorrow and hope he can straighten everything out for me. Thanks for your help. You guys frickin rule!!!
Old Jun 27, 2002 | 09:39 PM
woodog's Avatar
Default Re: I think I got the wrong Toda header.... (CStyles45)
you have the right header.
the header should/will fit on the head of any b-series motor. try again.
jdm headers such as the toda come with a different collector.
the exit is bigger and the flange is wider.
it is not going to be a bolt-on installation unless you have a custom hi-flo cat like the one offered by SMSP.
Old Jun 27, 2002 | 09:51 PM
ITRinEJ1's Avatar
u will need to either a) get a carsound/smsp cat or b) go to your local muffler shop and get a test pipe made. JDM headers such as toda is longer than your stock header so your stock cat is too long for the toda header
try it again after u get a shorter cat/pipe and everything should go on perfect
enjoy joo new toduhh powaahh
Old Jun 27, 2002 | 10:01 PM
CStyles45's Avatar
Default Re: I think I got the wrong Toda header.... (ITRinEJ1)
Ok...so I DID get the right header then. Boy, am I a moron! Was that the reason why we couldn't get the bolts on the head to line up then, because the header is longer or what? Hopefully I'll be able to go back to the shop and get it put on this weekend. Thanks for the help Leo, you saved me a long distance call for tomorrow.
Old Jun 27, 2002 | 10:05 PM
Drag R's Avatar
I'm not trying to sound like a jerk or anything, but WHY DO U PEOPLE GO TO THE DEALER FOR EVERYTHING AFTERMARKET??????????????
just a question.....
thanks
Nick
Old Jun 27, 2002 | 10:07 PM
CStyles45's Avatar
Default Re: I think I got the wrong Toda header.... (BeastyITR)
Actually, I should correct myself. My good friend that worked on my car is a mechanic at an Acura dealership. We just used their tools/lift to make the job easier. This was a "on the side" deal of sorts.
Old Jun 28, 2002 | 11:01 PM
t's Avatar
t
How long has he been a mechanic at the dealership??
1. He should of noticed the huge collector.
2. He should know that B-series heads have the same bolt pattern for the exhaust manifold.
3. All the flanges are made the same (I believe the todas are CNC also), so If your bolt holes are off, everyones is off.
4. The rear header bracket would need to swap to a JDM bracket (although I am not sure if the Toda header has the bolts for the bracket to attach to)
Old Jun 28, 2002 | 11:16 PM
Tommy_Gunns's Avatar
Yes...JDM header is longer than USDM header.
Old Jun 29, 2002 | 01:33 AM
Art Vandeleigh's Avatar
Default Re: I think I got the wrong Toda header.... (t)
serious man, how long has your buddy been a mechanic at acura??? thats why i never go there
Old Jun 29, 2002 | 06:37 AM
EagleR's Avatar
Default Re: I think I got the wrong Toda header.... (cali-r)
And to think....people think the dealer knows best.....
Old Jun 29, 2002 | 06:59 AM
sneakychaos's Avatar
Default Re: I think I got the wrong Toda header.... (EagleR)
I'm sorry, Toda What?
Old Jun 29, 2002 | 11:26 AM
ITR21's Avatar
Default Re: I think I got the wrong Toda header.... (trooth)
the dealership sucks and toda rules
Old Jun 29, 2002 | 11:46 AM
aznmc16's Avatar
Default Re: I think I got the wrong Toda header.... (ITR21)
dam JDM headers!! they're too fukin long. i got my JDM DC... i had to shorten my exhuast a lil.
Old Jun 29, 2002 | 01:47 PM
tecnic1's Avatar
Toda bling bling.
OMG WTF
Feb 5, 2006 11:52 AM
Declectic
Nov 7, 2005 10:31 PM
topspeed86
Sep 16, 2004 05:29 PM
YellowR2000x2
Mar 10, 2003 09:41 PM
rockwilda
Dec 30, 2002 12:47 AM
