Leaky Valve Cover?!?
Old Jun 27, 2002 | 09:17 PM
.Beaver's Avatar
Bloody Beaver
Default Leaky Valve Cover?!?
I have a 93 civic ex coupe with the D16Z6, of course. It has 109,000 miles on it, and already had all scheduled service done (t-belt, water pump, 3k oil changes, etc...) and I've never had a problem with it until now. Today I noticed a oily looking stain around the #1 Spark plug, on the valve cover, and it extends to where the valve cover meets the head. The plug wire on that cylinder has a little wetness at the top of the wire, that smells like oil/gas mixture. Also, the other day, when I was accelerating I noticed a strange little "tingy" noise that starts around 4500 rpm, that has since gone away, but now I saw that leak, and I think it may be related. Well sorry for the life story here, but I'd appreciate some input on whats goin on with my beloved
Old Jun 27, 2002 | 09:22 PM
sshaikh01's Avatar
Default Re: Leaky Valve Cover?!? (1 Evil Civic)
head gastkeeeeeeeeeeeet
Old Jun 27, 2002 | 09:30 PM
Kamin's Avatar
Default Re: Leaky Valve Cover?!? (sshaikh01)
sounds like head gasket
get a compression test done, asap.
Old Jun 27, 2002 | 09:31 PM
.Beaver's Avatar
Bloody Beaver
Really?
Even tho its up by the valve cover?
If thats the case, its B18 time, then
Old Jun 27, 2002 | 10:46 PM
AllMotorITR's Avatar
New User
Default Re: Leaky Valve Cover?!? (VTEC CX)
VTEC CX do you ever post anything beside thumb ups or restated information?
Old Jun 27, 2002 | 10:54 PM
JDMb18civic's Avatar
Default Re: Leaky Valve Cover?!? (1 FAST R)
vtec cx is disabled...dont be hating...
hahah j/p nema....
Old Jun 27, 2002 | 10:58 PM
.Beaver's Avatar
Bloody Beaver
Default Re: Leaky Valve Cover?!? (JDMb18civic)
I was just told by a mechanic, that its most likely the spark plug seal tube on that #1 cylinder, it would explain why its on the boot of the wire and all that, so 4 new ones, and a new valve cover gasket, and i'm good to go, thanks for the help
Old Jun 28, 2002 | 03:49 AM
hondafrk's Avatar
I will agree with 1 Evil Civic. Dudes how could it be a head gasket when it is leaking into the plug hole. Im a mechanic and It is always the seals around the plugs that leak oil into the plug hole. Just replace your v/cover gasket and they usually always come with 4 little seals for the plug holes and your good to go
Old Jun 28, 2002 | 11:53 AM
qbsi's Avatar
Default Re: Leaky Valve Cover?!? (hondafrk)
replace the head gasket and the little rubber things (sorry i dont know what they are called) that goes underneath the valve cover screws. my car was doing almost the same thing so i changed the gasket and those lil o looking rubber things and it fine now. oh btw, make sure you clean the valve cover with some simple green to make it clean after you change the gasket so you know if it leaks again.
good luck dude.
Old Jun 28, 2002 | 12:03 PM
rodrez.'s Avatar
Default Re: Leaky Valve Cover?!? (qbsi)
correct, just get the valve cover seal and the o rings that surround the spark plugs on the valve cover, and you should be good to go. Those orings usually tear a little due to changing/checking spark plugs, when you pull them out, they scrape on the oring.
Old Jun 28, 2002 | 12:07 PM
Jonathan_ED3's Avatar
lol...i don't think Neema does. i noticed like last week (literally) he had just over a thousand posts..and now it's almost 2thousand. those thumbsup will do wonders for a post count!
Old Jun 28, 2002 | 12:09 PM
Mike P.'s Avatar
25 Year Member
Yup, folks that are mentioning compression tests and head gaskets are WAYYYY jumping the gun. The obvious place to look is definitely the valve cover gaskets. That's a minor problem, and it can be done in 15 minutes or less. Some folks here seriously talk out of their asses, but nothing really comes out but a little *parf*
Old Jun 28, 2002 | 12:11 PM
riot's Avatar
Default Re: Leaky Valve Cover?!? (Mike P.)
Old Jun 28, 2002 | 12:14 PM
Mike P.'s Avatar
25 Year Member
Also, isn't the oil filler hole right by the #1 spark plug opening on the D16? Maybe a little dripped...someone was a tad sloppy...
Very likely.
B20Zer
Honda CR-V & Element
10
Jan 6, 2018 08:14 AM
fanta!
Jul 5, 2005 12:46 PM
fanta!
Jun 29, 2005 03:20 PM
coupon
Jun 29, 2005 08:56 AM
CalvitoSol
Jul 8, 2002 12:03 AM
