Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Pics or links to site for proper seat and harness mounting
Old Dec 20, 2007 | 09:23 AM
vbspec's Avatar
Default Pics or links to site for proper seat and harness mounting
I am looking at ways to safely lower my seating position and I also want to make sure that my harnesses are properly installed. I have used the stock 96 Integra sliders with a piece of 3/8 steel plate bolted to the sliders using #9.8 grade bolts then a piece of the same 3/8 steel acts as a washer and the seat (UltraSheild Pro Race) is sandwiched in between the plates again using #9.8 bolts. I know that this seat requires a seat back brace and I will be building one similar to the IOport model. Any pics of a welded-in rail system and harness mount locations would be very helpful.
After doing a search I see what I have done is fine but what are you guys using to get the seating lower in the car?
Thanx as always guys and happy holidays
cheers
Old Dec 20, 2007 | 02:05 PM
lightningd's Avatar
Default Re: Pics or links to site for proper seat and harness mounting (vbspec)
hey mike. i cut the humps out of my car and bolted it straight to the floor. i used backing plates (like bolt in roll cages) for reinforcement. my sparco seat sits high naturally, but after bolting it to the floor (with the sparco side mounts) i actually had to race it up a little bit. if you're stuck, maybe take a look at shawn's seats. he uses the stock sliders i believe and that seat feels like you're sitting on the floor.
DIRep972
Apr 10, 2004 04:06 PM
BolivianDc2
15
Sep 30, 2003 01:25 PM
BolivianDc2
Sep 29, 2003 01:04 PM
serious
Jul 8, 2002 09:49 PM
