UGR Valves?? WTF?
I just bought a bunch of S2K stuff from someone on here, No names, not trying to start ****, and instead if S2K high comp valves I received UGR hi comp valves.
Does anyone know if these are any good?? The rest of the stuff I can find from them on the net looks shady >.<. Do these suck? Did I get ripped a new one?
Let me know ppl!
Let me know ppl!
Anyone?? I think I'm going to toss them in the trash lol... The machining looks like *** and they dont measure up very well on the Mic >.<
If anyone can tell me different let me know!
i dont know much about UGR but wasnt there a thread back about a father and son using it on a lsvtec or b20vtec build up in a crx that ran pretty fast at the track. im sure someone else on here should know. i believe its D-Rob.
UGR is obviously gettin their cams from the same place that skunk2/blox are getting their cams from. i would assume the same about their valves. just a guess though
Yep, my father and I are using a complete UGR valvetrain in his B20VTEC CRX.
Car trapped 110mph last time we went to Beaver Springs.
While I won't go as far to say that the new Skunk2 products come from the same exact place, I wouldn't be surprised if the older Skunk2 stuff and UGR came from the same plant.
Here's what they look like.
So far, there has been no issues with them. Leakdown numbers on his engine are less than 4% on all cylinders, and compression tests great at 285psi across. There is absolutely zero oil consumption as well.
- Derek
- Derek
Yup,
those are the ones!! What I dont like is the way that some of the valve stems connect to the throat of the valves.
It just seems to me that, because of the angle, under heat stress the sides of the valve stem would expand at different rates and cause the head of the valve to be slightly angled.
I think it's more the inconsistancy of the valves that bothers me more than anything... they just look sloppy
First rule of thumb, if you do not like how they look, don't use them.
2nd rule of thumb, go with your own thoughts, and not internet crap.
3rd rule of thumb, buy new parts from the Mfg., then you do not have to whine on the internet if you do not like the part, just return them.
4th rule of thumb, you get what you pay for, and you deserve it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DonF »</TD></TR><TR><TD CLASS="quote">First rule of thumb, if you do not like how they look, don't use them.
4th rule of thumb, you get what you pay for, and you deserve it.</TD></TR></TABLE>
priceless MR DonF
Regards Dyno Dave
priceless MR DonF
Regards Dyno Dave
1: not using them.....
2: was trying to figure out what they were... had never heard of UGR
3: not whining, just fishing for info
4: what do I deserve? to get swindled openly? you take your chances when you buy anything from the internet... MFG or not..
Grow up! What is this forum here for if I can't ask a legit question...
go flame someone who cares
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by logg_frogg »</TD></TR><TR><TD CLASS="quote">
dude he has a stroller.....
</TD></TR></TABLE>dude he has a stroller.....
i don't think DonF was trying to personally attack you...... just take it with a pinch of salt..... hes someone that should be listened to seeing that hes been building race motors for longer then ive been alive most probably...its rare to have qualified real life experience talking directly too you..... Good luck with the build
Boner_Ben
25
Jan 19, 2006 08:05 AM
