FS: 1994 Integra Coupe
Old Dec 20, 2007 | 08:20 AM
pnthr30's Avatar
Default FS: 1994 Integra Coupe - $1750
Edit: Car is sold.
Up for sale is a 1994 Acura Integra Coupe (automatic)......the car is white with black interior (including black leather). The car has approximately 170K on the body - the tranny was just replaced with one that has approximately 40K on it. In short, you are good to go for some time......this car isn't a looker, but it will get you from point "A" to point "B". Mechanically, this car is VERY sound....great reliable transportation or a winter beater. Come and take it for a drive, you won't be disappointed!
Exterior:
First, let address the obvious..........the exterior can't quite be considered "showroom condition". More specifically, the passenger rear quarter panel has a bit of a rust problem.........but not to worry, I have an entire rear quarter panel taken off of another Integra that can be used to fix this - if you so desire.
Interior:
The interior carpet/floor mats are very clean for a car this age. The dash and trim pieces are all in tact and in good condition. The passenger seat is in good condition for its age. The rear seats are in good condition for their age. The drivers seat is in avg. condition for its age - some cracking.
Mechanical:
This is where this car shines............mechanically, this car is in very good condition (runs very smooth/quiet with no knocks), with a lot of work recently done. The following has recently been completed:
- new fuel lines
- new valve cover gasket
- new plug gaskets
- new oil pan gasket
- brand new battery
- new tranny
- newer aftermarket cat-back exhaust ("Borla" type)
- new ignition coil
- all fluids drained and flushed
Additional things to note:
- new matching tires (two tires are BRAND new)
- aftermarket remote detach face CD player
- wired for amp and speakers
- hatch area Dynamatted
As noted, included with this car will be an extra rear quarter panel so that the rust problem can be fixed.
Asking $1750
In addition to the above, I have some other Integra parts including a rear hatch, OEM tail lights, moonroof, hatch struts, seat belts and seat belt assemble, airbag module, and basically another entire interior (also black). So, if you need some parts/pieces, let me know.
Modified by pnthr30 at 10:32 PM 12/21/2007
mr_mbuna
May 28, 2004 03:58 AM
MrEg
Nov 20, 2003 07:53 PM
R-gonaut
Mar 8, 2003 07:01 PM
