vacuum diagram
hey man im not sure where to find the diagram but a good rule of thumb when it comes to vacuum is its all the same, a motor only generates vacuum when idling, when revving little to no vacuum is created due to there being no sealing effect in the manifold, with that said the same amount of vacuum is consistant at all points in the manifold unless u have a block somewhere but really the only vacuums u need are one from the charcoal canister to the manifold one from the pcv to the manifold and one from the fuel pressure regulator to the manifold other than that is u have any other ones block them off of plug them in if the manifold u are using allows for it
acmoc
Nov 30, 2008 09:45 PM
Nextelbuddy
Mar 26, 2004 05:08 PM
