84mm sleeved block
84mm gsr block with JG sleeves, JE 9:1 pistons, and eagle rods. everything only has about 8k, including the oil pump, rod bearings, water pump, and tensioner. before i took the motor out of my car i did a compression test and it read between 150-155 all across, on a harbor freight compression tester. the motor was broken in all motor using the "http://www.mototuneusa.com/break_in_secrets.htm" method. it burns about half a quart every 200 miles but im sure most built motors burn some amount. im asking $1100 obo
Modified by jonvo at 1:37 PM 12/20/2007
P12 EG6
Jan 22, 2009 05:26 AM
boostd hatch
Nov 3, 2007 09:56 AM
boostd hatch
Mid-Atlantic (Sales)
14
Sep 29, 2007 12:36 PM
