oxygen sensor problem. any ideas?
First i found out i was throwing codes number 1 and 41. then i wired up a new 4 wire universal 02 sensor. then it just threw code 1. all connections and fuses are good. pretty sure i wired it up right. couldn't find any help on all data. any ideas on what could be wrong? thanks.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hardedge »</TD></TR><TR><TD CLASS="quote">maybe your ECU prefers an OE type sensor rather than a universal.</TD></TR></TABLE>
I think that might be it. If your car is OBD2 then try moving your working secondary OE sensor to the primary location and install the universal one in the secondary location. The ECU needs a more accurate reading from the primary O2 sensor than the secondary one.
roy ezechukwu
Feb 6, 2014 02:13 PM
wakaranai
19
Nov 6, 2008 09:52 PM
bmoua
Apr 15, 2007 12:24 AM
ham
Apr 13, 2007 07:43 AM
