EF H2B Hood Clearance, is it a
Old Dec 19, 2007 | 07:51 PM
DC2_8.2K's Avatar
Default EF H2B Hood Clearance, is it a
Ok, I'm kinda confused here. I've read that with a H2B in a EF the valve cover would be hitting the hood, so you're going to have to do some modifications or get a different hood, and the SiR hood won't work either, from QuartersportDrag. Then yesterday I found this site:
http://www.explicitspeedperfor....html
With his crx and with his H2B Kit, with the stock hood, he's about 3/8" from hitting the valve cover.
Can anyone backup this information? Any info is greatly appreciated! Thank you!
Old Dec 19, 2007 | 09:17 PM
ESP.net's Avatar
Default Re: EF H2B Hood Clearance, is it a "myth?" (just_hatched)
My H22 Crx uses the H trans... no H2B here...i like my DD
Old Dec 19, 2007 | 09:33 PM
boosted dohc zc's Avatar
Default Re: EF H2B Hood Clearance, is it a "myth?" (ESP.net)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ESP.net &raquo;</TD></TR><TR><TD CLASS="quote">My H22 Crx uses the H trans... no H2B here...i like my DD</TD></TR></TABLE>
why did you even reply? that had nothing to do with his question at all hell you didnt even say if yours cleared or not
Old Dec 19, 2007 | 09:46 PM
1989CivicSi's Avatar
Default Re: EF H2B Hood Clearance, is it a "myth?" (boosted dohc zc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted dohc zc &raquo;</TD></TR><TR><TD CLASS="quote">
why did you even reply? that had nothing to do with his question at all hell you didnt even say if yours cleared or not </TD></TR></TABLE>
That sir, is the owner of explicitspeedperformance. That's his site and his H .
To the op: There is no myth, H2B in EF's tend to fit like complete ***. You have the choice between ground clearance, and hood clearance. Most people take the former over the latter .
Old Dec 19, 2007 | 09:49 PM
SIred91's Avatar
Rainman
Read before you post.
Old Dec 20, 2007 | 03:46 AM
I CRX I's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by just_hatched &raquo;</TD></TR><TR><TD CLASS="quote">Ok, I'm kinda confused here. I've read that with a H2B in a EF the valve cover would be hitting the hood, so you're going to have to do some modifications or get a different hood, and the SiR hood won't work either, from QuartersportDrag. Then yesterday I found this site:
Can anyone backup this information? Any info is greatly appreciated! Thank you!</TD></TR></TABLE> His car does not have an H2B kit, its the kit his company provides for the H22 motor and trans in an EF which to my understaing sits lower then an H2B kit hence the hood clearence. Some people choose to use the mounts provided by hasport to mount a gsr in a crx and there kits aim towards ground clearence more then hood clearence so my hood is actulaly spaced with just a gsr in it i can imagine how much higher an H22 block would sit but i would imagine a fiber images SIR style hood with spacers might clear but i havnt seen anyone attempt this yet.
Old Dec 20, 2007 | 06:29 AM
thevtecnician's Avatar
Default Re: EF H2B Hood Clearance, is it a "myth?" (I CRX I)
The hump in the sir hoods isn't wide enough for it to help clear the vc
Old Dec 20, 2007 | 07:03 AM
gibsanez's Avatar
Default Re: EF H2B Hood Clearance, is it a "myth?" (thevtecnician)
The explicit speed car is just a straight H22 swap, not an H2B.
QSD made a CRX that cleared the stock hood, but they used custom mounts and the engine was like barely an inch off of the ground, seriously.
Trust me, they don't fit either a stock or SIR hood without modifications.
Old Dec 20, 2007 | 08:42 AM
skunked's Avatar
Default Re: EF H2B Hood Clearance, is it a "myth?" (gibsanez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">
QSD made a H2B CRX that cleared the stock hood, but they used custom mounts and the engine was like barely an inch off of the ground, seriously.
yep, the pan hung down really low. Even on big *** 24.5" slicks at stock suspension height.
Old Dec 20, 2007 | 08:48 AM
Turbogixxer's Avatar
Default Re: EF H2B Hood Clearance, is it a "myth?" (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">
Mr. Skunked
there is more then motor height
tsk tsk
Old Dec 20, 2007 | 08:53 AM
skunked's Avatar
Default Re: EF H2B Hood Clearance, is it a "myth?" (Turbogixxer)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbogixxer &raquo;</TD></TR><TR><TD CLASS="quote">
Mr. Skunked
tsk tsk</TD></TR></TABLE>
Damn!! I see we have more than one magician on this board
Old Dec 20, 2007 | 10:52 AM
ESP.net's Avatar
Someone needs to make a metal Cowl for the EF H2B's! or I am going to get the wheel out and start making some lol
Modified by ESP.net at 12:08 PM 12/20/2007
Old Dec 20, 2007 | 10:55 AM
skunked's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ESP.net &raquo;</TD></TR><TR><TD CLASS="quote">Someone needs to make a metal Cowl for the EF H2B's! or I am going to get the wheel out and start making some lol</TD></TR></TABLE>
It really wouldn't take much. Metal or even a fiberglass molded piece just large enough to cover the valve cover and intake manifold.
Old Dec 20, 2007 | 11:07 AM
gibsanez's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">It really wouldn't take much. Metal or even a fiberglass molded piece just large enough to cover the valve cover and intake manifold.
That or a low-profile valvecover
Old Dec 20, 2007 | 11:12 AM
ESP.net's Avatar
Here is what I would do if i was a DIYer H2B EFer
go to the junkyard pick up 2 $25 EF hoods to make one, cut the center section out about 1" or so around the dip down in the EF hood, have the cut out middle section of one hood and prop it up about 2" or so up to the person above the stock hood make some sides for it out of metal, weld it up. Cut the middle section out of the hood once everything is welded together and brace if needed... the front would have the OEM contour but just propped up so the slant in the front would go up like OEM but higher lol...
Old Dec 20, 2007 | 11:50 AM
skunked's Avatar
That or a low-profile valvecover </TD></TR></TABLE>
still doesn't help the guys running the Skunk2 manifold.
I'd rather see something smaller and lighter personally. Adding more steel to a factory steel hood will be too heavy for competition IMO.
Old Dec 20, 2007 | 12:14 PM
gibsanez's Avatar
Forgot about that. A well-fitting fiberglass cowl hood would be nice
Old Dec 20, 2007 | 12:30 PM
black0hatch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ESP.net &raquo;</TD></TR><TR><TD CLASS="quote"> 2 $25 EF hoods </TD></TR></TABLE>
what!? where? i need a 25 dollar hood.
Old Dec 20, 2007 | 12:35 PM
DC2_8.2K's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gibsanez &raquo;</TD></TR><TR><TD CLASS="quote">The explicit speed car is just a straight H22 swap, not an H2B.
Thank you for the pic? I see now. Well, if no hood works, and the only way is to go with a cowl hood, that'll lose the sleeper look to it then.
Hmmmmmm.......
Old Dec 20, 2007 | 12:45 PM
gibsanez's Avatar
Hmmmmmm....... </TD></TR></TABLE>
It's just something you have to sacrifice for the ground clearance and axle angles. This is by no means a practical swap for the EF/DA chassis. Think I care though? Not a bit
Old Dec 20, 2007 | 01:30 PM
STREETWERKZ's Avatar
ballsy idiot n00b! why did you reply?
Old Dec 20, 2007 | 01:31 PM
EF_9's Avatar
wil the hood spacer work or is it still too low??? thats what i had on my LS swap
Old Dec 20, 2007 | 01:38 PM
grog's Avatar
Default Re: (EF_9)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EF_9 &raquo;</TD></TR><TR><TD CLASS="quote">wil the hood spacer work or is it still too low??? thats what i had on my LS swap</TD></TR></TABLE>
look at that side profile picture, you would need to space it like 5 inches up. plus it looks like the hood in the pictures has washers proping it up already.
Old Dec 20, 2007 | 01:45 PM
EF_9's Avatar
Default Re: (grog)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by grog &raquo;</TD></TR><TR><TD CLASS="quote">
look at that side profile picture, you would need to space it like 5 inches up. plus it looks like the hood in the pictures has washers proping it up already.</TD></TR></TABLE>
true
Old Dec 20, 2007 | 03:15 PM
gibsanez's Avatar
Default Re: (EF_9)
Correct, in the picture the hood is spaced up about a half inch at least. I'll show you some pictures from when I just "set" the hood on before any cutting of the webbing or anything. This is just the stock hood "sitting" on the valvecover.
