Texas -OK -LA (Sales) Texas, Oklahoma, Louisiana
Acura-Honda 97 GSR LONG BLOCK - $700
Old Dec 19, 2007 | 07:24 PM
Seto-Initial-B's Avatar
Default Acura-Honda 97 GSR LONG BLOCK - $700
SOLD SOLD SOLD SOLD SOLD SOLD
IF THIS AD IS STILL POSTED .... THE ITEM IS STILL AVAIABLE!!!!!!!!!!!!!!!!!!!!!!!! so give me a call.....
I will not be able to update the AD intill my new home gets hooked up for the net again. I will try to reaspond to emails when i can get to someones home with roadrunner. For now please call me.
This Longblock B18c1 GSR engine was pulled out of my 1997 GSR. I am the Secound owner of the
vehical and have replaced the Oil pan gasket, Solenoid gasket, sollenoid fliter spool V, Rear Cam seal,
Head cover gaket,Rear main Seal, Crankshaft pulley after being pulled. I have all my receits and the Frist
and only owners reciets for replacing the "Timing belt,Water pump,cam seals, crank seal.What you see
in the photos on the Longblock comes with it. The long block will Include Vetec solenoid, intake
mainfold, throttle bodie, injectors and fuel rail, dizzy , vtec soilanoid, and all the nessary brakets for
attatching your compressor,alt,P.S.
the engine had 119k miles when I got the Integra and I pulled the engine at 122k miles. This engine RAN GREAT... even when it burned alil oil due to the valve Seals starting to go bad.
Okay ....... So why so cheap. 700 dolors is un heard of for such an engine .... even online ! ! ! !
After purchasing the car the Valve Seals that keep the oil from slipping through the valve holes started
to wear down. This made the engine to burn alil oil at full timing at VTEC around 6000rpms to
8000rpms. I decided to pull the engine to rebuild for another car project. I had started to replace all the
seals and get it ready to be sent off for the valve seals to be replaced and I recently have lost my job. I
have no income to keep doing this project. My loss your gain to a GREAT FAST CAR...... This price is
ment to sell quick and SAVE YOU MONEY!!!!! I like to get a more suitable price like 1200 bucks ,but I
have to be realistic that most people dont know how to work on cars and have to shell out cash to
others to do the work. So i decide to make the price for all you LOW BALLERS ! nuff said !
This is perfect to set up in a 92-95 civic , 94-2001 integra...... Even The older CIVICs like 88-91 CRX's are great bodys to install an engine in.
PLEASE READ THE INFORMATION ABOVE ........ for all your details .... I will not be rude to explain again
,but I will act like your a dumba$$ if you ask for information that is LISTED ABOVE !!!!!
Modified by Seto-Initial-B at 7:14 PM 12/20/2007
HypL
Northeast (Sales)
Mar 18, 2015 06:18 AM
jrp355
Dec 27, 2012 06:54 PM
blue96integra
Sep 13, 2012 03:01 PM
nycjdmwhore
Apr 27, 2012 01:55 AM
hpmx18
Jan 3, 2010 02:40 PM
