Wiring walk-through? My car is b0rked
Ok, the problemo is that someone has wired an alarm into my car and i have no remote or control over the alarm. What i would like to know is, how do i go about removing the alarm( i know this seems easy, its not) The alarm has a remote-start module as well as some of the sh!ttiest wiring i have ever seen. Any/all picture from under-the dash with wiring, any write-ups on how to remove complete chassis harness, any pictures of the under-dash harness layed out. Any form of resource related to the wiring at hand would be greatly appreciated. Thank you all so much.
edit: guess it helps if you know what car, derr. 92 CX hatch, 5sp, obd1 b16a swapped. Thank you all. BTW, i have a complete engine harness, but i would like to remove the chassis harness first so i can lay it out and remove the alarm wiring. PS, i have everything up to the dash/fuse box out as well as most of the cluster wiring. Thank you again!
It does, the worst part is that it has a fuel pump cut-off. I removed the wiring for that because it was causing my car not to start. Now i just have miles of un-used 10ga wire going everywhere that i dont need whatsoever.
tominos
Audio / Security / Video
Mar 14, 2005 02:27 AM
