rattle can stock colors?
Old Dec 19, 2007 | 05:07 PM
trevorjohn88ef's Avatar
Default rattle can stock colors?
does anyone know of a website that sells stock colors of paint for honda (YR88 almond cream 1988 civic) in a rattle can? thanks
Old Dec 19, 2007 | 09:08 PM
toyomatt84's Avatar
Sanji
http://www.paintscratch.com
Old Dec 20, 2007 | 08:12 AM
civicandy's Avatar
Default Re: (toyomatt84)
There is a chainstore called Finishmaster that makes spray cans of oem colors. I've bought numerous cans for touch ups from them. It helps to soak the can in hot water for 10-15 min before you use them. Thats true for most spray cans
Old Dec 20, 2007 | 11:23 AM
Default Re: (civicandy)
soak in water? how does this help? and thanks i'll check them out
Old Dec 20, 2007 | 12:00 PM
civicandy's Avatar
Default Re: (trevorjohn88ef)
If you get the paint warm it helps it atomize or something like that. SCC painted a wrx flat black with spray paint and they soaked all the cans in hot water. I've actually tried it, and it seems to work. Put the can in a plastic bag so the label doesn't get destroyed.
I should point out, you don't want to heat the can with a torch or anything that could cause it to explode. I just use a bucket and hot water.
Old Dec 20, 2007 | 12:41 PM
kudude's Avatar
if the can is warmer the contents are under higher pressure, which is good to help the spray cans spray more evenly
Old Dec 20, 2007 | 07:29 PM
Default Re: (kudude)
learn something new everyday
kasperxtcy
Paint and Body
Apr 24, 2008 09:28 AM
ColMustard
Paint and Body
Jan 22, 2008 11:40 PM
iv4hcx3l4
Paint and Body
16
Nov 12, 2007 09:54 PM
O16581724 5 2 5
Paint and Body
Aug 25, 2007 10:48 AM
FortunateFool.
Jun 6, 2005 08:11 PM
