has anyone had cam cap or tower movement? see a use for this?
Old Dec 19, 2007 | 04:57 PM
Jared's Avatar
Default has anyone had cam cap or tower movement? see a use for this?
I don't know that I've ever seen a byproduct of what this claims to fix. And it's odd that if you peruse the rest of the site, they don't really make **** else for imports. Anyone?
http://www.hitechledproducts.c...c2bfb
Old Dec 19, 2007 | 05:00 PM
( o )( o )'s Avatar
Default Re: has anyone had cam cap or tower movement? see a use for this? (Jared)
a) never heard of the product
b) never heard of needing the product
c) how do they know it will fit? I thought that cam caps and heads must match because they are align bored from the factory...wouldn't this need an alignment to be sure the cams won't seize?
Old Dec 19, 2007 | 05:09 PM
4piston's Avatar
Default Re: has anyone had cam cap or tower movement? see a use for this? (( o )( o ))
If you run a large cam with a bunch of lift, the cam will deflect. If your cam deflects 10 thou, that is 10 thou of lift that you lose. I would be interested to see how this stiffens things up.
It looks like an elaborate piece and well worth the price. I think it would be worth a try.
Old Dec 19, 2007 | 06:09 PM
Jared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ( o )( o ) &raquo;</TD></TR><TR><TD CLASS="quote">a) never heard of the product
c) how do they know it will fit? I thought that cam caps and heads must match because they are align bored from the factory...wouldn't this need an alignment to be sure the cams won't seize?</TD></TR></TABLE>
i think this just replaces the rails on top of the cams so no line bore should be needed.
Old Dec 19, 2007 | 06:10 PM
Jared's Avatar
Default Re: has anyone had cam cap or tower movement? see a use for this? (4piston)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4piston &raquo;</TD></TR><TR><TD CLASS="quote">If you run a large cam with a bunch of lift, the cam will deflect. If your cam deflects 10 thou, that is 10 thou of lift that you lose. I would be interested to see how this stiffens things up.
It looks like an elaborate piece and well worth the price. I think it would be worth a try.</TD></TR></TABLE>
Agreed. I'm thinking about carving up a valve cover so i can run the engine with a dial indicator installed at the cams and caps without slinging oil everywhere.
Old Dec 19, 2007 | 08:48 PM
Combustion Contraption's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">
Agreed. I'm thinking about carving up a valve cover so i can run the engine with a dial indicator installed at the cams and caps without slinging oil everywhere.</TD></TR></TABLE>
Old Dec 20, 2007 | 03:17 AM
non-VTEC's Avatar
that would be a good idea to see if they actually have any movment....for some reason even with big lift cams and high rpm i dont think the cam/caps will move....
Old Dec 20, 2007 | 04:34 AM
IntegraType-R's Avatar
Default Re: has anyone had cam cap or tower movement? see a use for this? (Combustion Contraption)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Combustion Contraption &raquo;</TD></TR><TR><TD CLASS="quote">
...</TD></TR></TABLE>
LMFAO...
on the other hand this thing looks like a cool piece of ****, but i wouldn't try it, someone let me know how it goes.
Old Dec 20, 2007 | 07:52 AM
Chris Tune's Avatar
Default Re: has anyone had cam cap or tower movement? see a use for this? (IntegraType-R)
someone will use it cause it was post on HT and it's "bling"...
Old Dec 20, 2007 | 08:15 AM
Furyof4's Avatar
Default Re: has anyone had cam cap or tower movement? see a use for this? (Chris Tune)
Now we need a custom clear valve cover so we can see all that bling!!
Old Dec 20, 2007 | 09:17 AM
Bury Your Dead's Avatar
* B A N N E D *
Default Re: has anyone had cam cap or tower movement? see a use for this? (Furyof4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Furyof4 &raquo;</TD></TR><TR><TD CLASS="quote">Now we need a custom clear valve cover so we can see all that bling!! </TD></TR></TABLE>
dont forget to install mini windsheild wipers for all that chaotic oil slinging fury.
wanna know what this does? makes you have to loosen both cams up instead of one.
Old Dec 20, 2007 | 01:25 PM
Aquafina's Avatar
Default Re: has anyone had cam cap or tower movement? see a use for this? (Bury Your Dead)
Brad put a window in a oil pan and use a high speed camera to look at flex on a B series bottom end. Could do the same for the head.
Old Dec 20, 2007 | 04:14 PM
burningrex's Avatar
Looks retarded... sounds like they came up with some positive use for it over your stock rails... but doubt it will work...
But i would't put that thing on my head...
Old Dec 20, 2007 | 05:02 PM
Jared's Avatar
so typical honda-tech. no one has any information on it except for "oh bling" and "i wouldnt use it because its not bandwagon"
oh wells
Old Dec 20, 2007 | 06:45 PM
CONTROLLED CONFUSION's Avatar
Default Re: (IntegraType-R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">so typical honda-tech. no one has any information on it except for "oh bling" and "i wouldnt use it because its not bandwagon"
oh wells</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by IntegraType-R &raquo;</TD></TR><TR><TD CLASS="quote">
Yes, thats it..
How about this you go buy it and tell it how it works, please prove us wrong.. otherwise shut the hell up.. nobody wants to put anything on they're motor if they dont know **** about it..
are you a moron?? Go buy a set of obx stage 10 cams and tell me how they work out.</TD></TR></TABLE>
so typical. lol
oh wells
boosstboy's Avatar
Yes, thats it..
why the response , it's true that no one will try anything new unless everyone else does it, or damn thats so bling. i would be interested in more info as i will be running the same cam setup jared is currently running. not saying it will fix anything but y not test it to prove wrong.
Old Dec 20, 2007 | 06:51 PM
boosstboy's Avatar
Default Re: (boosstboy)
hey jared if you are serious about testing it, and have equipment to do so i would be willing to put $50 towards the purchase and testing time of the part to you. it's not much but if enough people are willing to give some $ for r & d it can add up.
Old Dec 20, 2007 | 07:09 PM
Jared's Avatar
Yes, thats it..
I can tell you I've put more time into "seeing what works" that you will ever work on cars in your life, and most likely I've forgotten more about them than you will ever know. I'm merely asking if anyone has tried this item, no need to get all butt hurt. You and those like you are the problem with this industry. Read into that what you may, but oddly enough, this didn't turn into a flame-o-rama in the drag racing forum where mostly adults peruse.
Jared's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosstboy &raquo;</TD></TR><TR><TD CLASS="quote">hey jared if you are serious about testing it, and have equipment to do so i would be willing to put $50 towards the purchase and testing time of the part to you. it's not much but if enough people are willing to give some $ for r & d it can add up.</TD></TR></TABLE>
Keep in contact with me, I'm looking for a valve cover to destroy.
Old Dec 20, 2007 | 07:23 PM
boosstboy's Avatar
Default Re: (Jared)
Old Dec 20, 2007 | 07:54 PM
4piston's Avatar
Yes, thats it..
Did you not hear? It stiffens the towers up to prevent cam deflection.
Old Dec 20, 2007 | 11:57 PM
Aquafina's Avatar
Default Re: (Jared)
I can tell you I've put more time into "seeing what works" that you will ever work on cars in your life, and most likely I've forgotten more about them than you will ever know. I'm merely asking if anyone has tried this item, no need to get all butt hurt. You and those like you are the problem with this industry. Read into that what you may, but oddly enough, this didn't turn into a flame-o-rama in the drag racing forum where mostly adults peruse.</TD></TR></TABLE>
I can vouch for this. Jared tested out the first Rocket Motorsports M21X cams ever made. I believe he also installed the first RM cams used in a street car in Tennessee on his brothers car.
Old Dec 21, 2007 | 06:58 AM
Rocket's Avatar
Default Re: (4piston)
Not needed.
The head, stock cam caps that straddle both cams do need help here. Maybe to win at the local Hot Import Nights when you flip your valve cover.
Old Dec 21, 2007 | 08:31 AM
Did you not hear? It stiffens the towers up to prevent cam deflection.</TD></TR></TABLE>
its not needed..its just extra bling..
Old Dec 21, 2007 | 09:07 AM
98vtec's Avatar
moderator emeritus
its not needed..its just extra bling..</TD></TR></TABLE>
seriously....stop posting. Would you like me to bring up the old threads of your past so we can make fun of you over and over again?
yea thanks. shut the expletive up.
Jared, i would be interested in atleast getting more information on this topic. If you need any help, shoot me an IM....
