s2s2 or stock pr3 cams?
Old Dec 19, 2007 | 04:57 PM
civickid03's Avatar
Default s2s2 or stock pr3 cams?
I have the valvesprings and retainers to support the s2s2 cams I have in there now, including upgraded lost motion assembly. I have a obd0 b16a stock compression, cam gears, fpr, vafc. Should I opt for the pr3 cams instead due to the stock compression of the motor?
Old Dec 20, 2007 | 04:28 PM
StorminMatt's Avatar
Default Re: s2s2 or stock pr3 cams? (civickid03)
From what I have heard, S2S2 cams like high compression - 11:1 and higher. So they would not be the best choice for a stock B16A, which only has 10.2:1. If you don't ever plan to increase compression, you can either go stock, or go with the S2S1.
g23cg5
Nov 15, 2013 04:58 AM
nikanoras
Feb 16, 2010 10:26 PM
nokturnal_munkeeboy
Jul 23, 2006 08:50 PM
tomlinson619
May 22, 2006 07:59 PM
bxsi
Apr 2, 2004 05:42 AM
