What parts to Buy when building up a ZC???
Old Jun 27, 2002 | 07:24 PM
hondaless's Avatar
Default What parts to Buy when building up a ZC???
I have a 88 CRX Si with a DOHC ZC engine....in the winter i was thinking about building up the engine can someone help me out and tell me he parts i need etc.... like what rods to get, Pistons, and studs. I am just starting to learn about engines so your help would be appreciated. I am hoping to reach atleast 150HP to the wheels ALL MOTOR. I will post some pics of my CRX as soon as i get it back it is kinda Ricey but i am going to make it fast also don't worry.
Old Jun 28, 2002 | 04:56 AM
keithv's Avatar
Default Re: What parts to Buy when building up a ZC??? (evilcrx)
for a stock parts list, check this out:
http://kjvieira.tripod.com/ZC_info/parts_list.xls
note: you must copy and paste the link b/c tripod ***SUCKS***
Old Jun 28, 2002 | 04:24 PM
hondaless's Avatar
Default Re: What parts to Buy when building up a ZC??? (breaka_1_9)
I need to know like the Internal parts of the engine.... like connection rods, is there a different valve tran i can get? what pistons stuff like that.
Old Jun 29, 2002 | 09:04 AM
-TJ's Avatar
-TJ
You can get pistons/rods from Endyn (www.theoldone.com). I'm putting together a NA D16A1 (internally the same as a ZC) with Eagle rods, and the 11.8:1 CR rollerwave pistons. There isn't much in the way of valvetrain available for ZC's. A variety of regrind cams, or the infamous HKS units if you can find them.
You can get ARP fasteners, but they don't offer a "kit". I'm using the Chrysler 2.2 kit for the bottom end and a B series kit for the head. There's only a few fasteners that don't work because Honda uses longer lengths in the center of the block/head. You can get the correct lengths from ARP individually.
Old Jun 29, 2002 | 01:23 PM
*Boostwerks*'s Avatar
Default Re: What parts to Buy when building up a ZC??? (-TJ)
Do you have a part# for the "chrysler 2.2" bottom end kit?
Old Jun 29, 2002 | 03:40 PM
-TJ's Avatar
-TJ
Default Re: What parts to Buy when building up a ZC??? (Bryson)
Yep....
I think these are ARP's part numbers, I took them right off the boxes:
Bottom end = 241-4501 (chrysler 2.2l)
head = 208-4303 (Acura VTEC)
Old Jun 30, 2002 | 12:07 AM
Great!!
BTW, how much was the chrysler set?
Thank's a lot!!
Bryson
Old Jun 30, 2002 | 06:56 AM
-TJ's Avatar
-TJ
I don't remember how much...I got 'em from either Jegs or Summit
Old Jun 30, 2002 | 12:04 PM
EF'n Fast's Avatar
http://www.d16a.com
Good stuff. Owner's on the board and has those crx meets in Whittier every month or so.
http://crx.honda-perf.org/articles/b...udgetmods.html
An excellent article on budget mods.
-Eddie
[Modified by EF'n Fast, 2:47 AM 7/1/2002]
grandtheftlunchbox
Mar 30, 2008 09:14 PM
mrmechanic
Jun 29, 2004 10:29 PM
ZaksZCrex
Dec 29, 2003 08:05 PM
Dan Norton
15
Oct 16, 2003 07:17 AM
