Fully Built h22 FS, S2k proseries intake manifold, Ramhorn manifold Etc
All of this stuff is for an h22.
Skunk2 Proseries Intake manifold - $250
M2Y4 Transmission (20,000miles Confirmed!!! it was my friends moms old trans) Zero grinds whatso ever, it also comes with a brand new slave cylinder - $700
Ramhorn Turbo manifold, Jetcoated, modified alternator bracket for waste gate clearance - $800
Built Bottom End (all brand spanking new)
Benson sleeved h22a block 89mm bore
Wiesco 89mm pistons/pins/rings
Good for 9:5:1 compression ratio
Eagle rods
Kasimspeed balance shaft eliminater kit
Benson OEM mirco polished crank
Looking for - $2500 and i do not want to part out
H22 head
Fresh Hot tank, valve job, resurfaced, Supertech valve seals installed, completely rebuilt. Mint shape. Valve cover and oil cap included. $700
Modified by Prudz_lude at 5:46 PM 12/19/2007
Eagle rods
H22 head
what is the size of the intake manifold compared to the stock? My h22 is in a civic and the stock manifold is almost touching the firewall, so it can not be any longer than stock, and would be best if it were shorter.
Everything is sold except the transmission. The transmisson has also dropped to $500 shipped.
Prudz_lude
Canada (Sales)
Dec 19, 2007 04:40 PM
