Suspension & Brakes Theory, alignment, spring rates....
tire alignment?????
Old Dec 19, 2007 | 03:02 PM
JLefevers's Avatar
Default tire alignment?????
Ok my car is lowered about 1 1/2in. (i have no camber kit) and I am getting very odd tire wear. inside is bald, then thread, then bald, then tread again. (from left to right) So i was thinking that the tires are toed in very bad. Ok so I went to go get a tire alignment and when they put it on the rack he told me he could not do anything for me do to me not having a camber kit. My car is not slammed and I was under the impression that my problem was toe and not camber. when I asked him if he could just get it close he said no. So my question is do i need to get a camber kit and try again or are these guys just trying to get more money out of me????? He also made a comment about my tire size. I am running 99-00 si's with 205/50/15. he made the comment that my car is supposed to have 14's (93 hatch) and that my speedo is off like 10 mph i was like WTF??? Y would this have anything to do with alignment?? if i was running 195/65/14's it seems to me that swithing to 205/50/15's should be about the same in actual diameter. any info would be great thanx..
Old Dec 19, 2007 | 03:35 PM
baller status's Avatar
Default Re: tire alignment????? (JLefevers)
That guy was an idiot. Most alignment techs are stuck up idiots.
Your camber is not adjustable (just like 90% of all other cars on the road) but he could have set the toe.
You can verify that your wheel/tire size is the same by searching for an online tire aspect ratio calculator.
Old Dec 20, 2007 | 05:55 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
True. Just go to a different shop and tell them you need your toe aligned on all 4 corners, and that is all.
Old Dec 20, 2007 | 06:18 AM
JLefevers's Avatar
Default Re: (PatrickGSR94)
see thats is what i was thinking the whole time. thanx for the info
Old Dec 23, 2007 | 03:09 PM
iluvmy2000civicex's Avatar
Default Re: (JLefevers)
Same thing happened to me. No use spending hundreds of dollars on a camber kit. Just have the toe adjusted. U didnt pay this idiot anything did you?
B16CRXT
Suspension & Brakes
Jul 20, 2006 09:38 PM
lavo81
Suspension & Brakes
Aug 4, 2005 05:15 AM
97EXB18C
14
Jul 28, 2005 09:05 PM
4DRPIMPIN
Suspension & Brakes
28
Feb 24, 2005 09:11 AM
