Headers for my SUV Non-Honda
Old Dec 19, 2007 | 02:14 PM
JDMCRX's Avatar
Default Headers for my SUV Non-Honda
Hey guys making some headers for my Grand Vitara.
Here are some pics of what im up too.
DRIVERS SIDE HEADER 36-38" primaries
PASSENGER SIDE HEADER 34-36" Primaries gonna lengthen it to 36-38
Well guys here are the headers finaly welded up just got to do the 3 bolt flanges and finish up the Y pipe.
Y Pipe all tig welded with cats and 5 02 bungs
Drivers side collector brace
Well truck is pretty much done ill take some shots when its outside.
Here is the new Crossmember i had to make cause mine ended up at the local land fill
Modified by JDMCRX at 8:08 AM 12/30/2007
Modified by JDMCRX at 6:15 AM 1/6/2008
Old Dec 19, 2007 | 03:36 PM
DESTROYER's Avatar
Rad. I love those spun magnaflow cats, they are great for making power where the car/customer absolutely has to run a cat.
Old Dec 19, 2007 | 03:40 PM
m R g S r's Avatar
Default Re: Headers for my SUV Non-Honda (JDMCRX)
hrmmm.....whats the potential of the motor in a vitara?
Old Dec 19, 2007 | 03:42 PM
JDMCRX's Avatar
Default Re: Headers for my SUV Non-Honda (m R g S r)
The H25 is the same more as the H27 just 84mm bore vs 88mm in the H27 which is the motor they use in the Suzuki Pikes which makes 1000 hp.
Old Dec 20, 2007 | 03:01 PM
ELSpool's Avatar
looking good Josh!
Old Dec 20, 2007 | 06:11 PM
weiRtech's Avatar
OG Fabricator
looks hot, but what a shame to have all that room for a turbo and not take advantage of it!
Old Dec 20, 2007 | 09:02 PM
FastCougar's Avatar
Default Re: (weiRtech)
Looks like your transfer case has an front output shaft seal leak that is splattering the trans support and bottom of the trans and the trans has a case leak as well ... I'd keep an eye on fluid level.
Old Dec 20, 2007 | 11:34 PM
JDMCRX's Avatar
Default Re: (FastCougar)
Yeah i know the case has a small leak. I only loose maybe 100ml every few months. The main leak is the front drive shaft out put seal it pisses all over thanks I got the seal here for it along with new Greaseable U joints.
I would love to turbo it. I got a M62 super charger im going to try and if that fairs out maybe some twin GT28RS
Old Dec 21, 2007 | 09:22 AM
Alchemist's Avatar
Default Re: (JDMCRX)
Can you PM me how much the materials cost you and where you purchased everything from?
Old Dec 21, 2007 | 09:29 AM
GTibunny16v's Avatar
Default Re: (Alchemist)
Looks good but thats a really long tube header for a relatively low revving V6. Gotta report on how it feels after you're all done.
Also, are you fabbing up a dual exhaust or just using a Y pipe to a single back?
Old Dec 21, 2007 | 10:11 AM
project dc2's Avatar
Default Re: (GTibunny16v)
whered you get the collectors ?
Old Dec 21, 2007 | 12:02 PM
onefstek's Avatar
Looks like the choke on those collectors are a bit too big for your motor. Did you do any research before you got the parts?
Fabrication looks good, btw.
Old Dec 21, 2007 | 01:39 PM
JDMCRX's Avatar
Default Re: (onefstek)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by onefstek &raquo;</TD></TR><TR><TD CLASS="quote">Looks like the choke on those collectors are a bit too big for your motor. Did you do any research before you got the parts?
Fabrication looks good, btw. </TD></TR></TABLE>
What do you mean by the choke on the collectors?
The primaries are all 32-34" All within 1-1.5" of each other
The collectors are from DANIELM3 Very nice work on them ill post more pics of them soon.
Im going to by Ying them together after the tranny to a 2.5" manderal exhaust for now. When I super charge the truck i will probly go to a single 3"
Old Dec 21, 2007 | 01:43 PM
JDMCRX's Avatar
Your refering to the collector size outlet? Its 2.5".
This motor makes its peak power at 6,700 it revs up to 7500.
Its a V6 2.5L quad cam 24 valve.
I did a 2.5" Downpipes on the stock manifolds to see what kind of power i could pick up and wow what a difference jsut a Downpipe did. The truck woke up alot. another note. When i was towing my 2 sleds up and down the hills i notice a bit more grunt. They weight around 2500 with trailer and all.
Old Dec 21, 2007 | 04:41 PM
cbmprelude's Avatar
* B A N N E D *
This is pretty neat, what year is your vitara and what sort of power gains are you expecting? Can you post some overall shots?
Old Dec 21, 2007 | 06:22 PM
danielm3's Avatar
Default Re: (cbmprelude)
Good to finally see the header in production, you have been wanting to build it for a long time!! Looks pimp!
Old Dec 21, 2007 | 08:03 PM
onefstek's Avatar
Yes the collector outlet is too big for you 3 cyl's.
Old Dec 22, 2007 | 01:49 PM
JDMCRX's Avatar
Thanks Daniel
Well got the drivers side almost done more pics. Just got to put the number 1 runner and im done and i can tig it all up and hope nothing moves lol
Old Dec 24, 2007 | 09:16 PM
JDMCRX's Avatar
Just on a side note they are 36-38" long primaries. This motor revs out to 7500 rpm and is a 2.5 Litre
Old Dec 25, 2007 | 05:10 PM
Turbo EG4's Avatar
From: Ghost riding my grandmamas whip YEP, Los Angeles Cali
nice
Old Dec 28, 2007 | 07:35 PM
JDMCRX's Avatar
Default Re: Headers for my SUV Non-Honda (Turbo EG4)
New update one header fully welded took me about 3-4 hours per header to fully weld it.
Did the 2 into 1 merg Y pipe ill post more pics tonight.
Old Dec 28, 2007 | 07:43 PM
danielm3's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JDMCRX &raquo;</TD></TR><TR><TD CLASS="quote">New update one header fully welded took me about 3-4 hours per header to fully weld it.
Did the 2 into 1 merg Y pipe ill post more pics tonight.</TD></TR></TABLE>
I remember the 1st time I welded a header, **** took me about 7 days of about 5 hours a day of work to get my 1st set of the N/A is300 header done that I make now.
Now, almost 2 years later, I make one set in 5 hours including the bending .
Old Dec 28, 2007 | 10:47 PM
JDMCRX's Avatar
Default Re: Headers for my SUV Non-Honda (danielm3)
I know what you mean you look at it and your like this will take a bit, few hours later your still cracking at it.
Just was hard to get use to the tight angles. I am going to look for a smaller torch head for the tig later on for the tight angles and also make a tool to hold up the pipe while i weld it.
Old Dec 31, 2007 | 09:34 AM
vestalfootball72
Guest
Posts: n/a
looks good--
why 5 02 sensors tho? is one for a wideband?
Old Jan 1, 2008 | 08:54 PM
JDMCRX's Avatar
Default Re: Headers for my SUV Non-Honda (vestalfootball72)
Yeap Truck has primaries and secondaries and im gonna put my PLX on the truck and see if its leaning out at all with all these mods.
