H2B Question!?!
Old Dec 19, 2007 | 01:57 PM
h-duced's Avatar
Default H2B Question!?!
Ok this is what im workin with I got a H swap in my 97 coupe and as many of you know you have to cut a hole in the floorboard to put the shifter in. I have had the swap for so long and now there is the whole H2b craze goin on. Next summer i will be around 500 whp i want a more reliable trans to put in and h2b sounds like the ticket. How would i go back to linkage after i hacked a hole through my floor to run cables
Old Dec 19, 2007 | 02:22 PM
Syndacate's Avatar
Default Re: H2B Question!?! (h-duced)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h-duced &raquo;</TD></TR><TR><TD CLASS="quote">Ok this is what im workin with I got a H swap in my 97 coupe and as many of you know you have to cut a hole in the floorboard to put the shifter in. I have had the swap for so long and now there is the whole H2b craze goin on. Next summer i will be around 500 whp i want a more reliable trans to put in and h2b sounds like the ticket. How would i go back to linkage after i hacked a hole through my floor to run cables</TD></TR></TABLE>
I always wondered this myself, as in what would happen if you had an H/F swap and wanted to convert back to a typical linkage.
My answer: Welder + Sheet metal
Old Dec 19, 2007 | 02:23 PM
h-duced's Avatar
Default Re: H2B Question!?! (Syndacate)
i think thats what its goin to come down to
Old Dec 20, 2007 | 07:42 AM
superfast666's Avatar
if u look at the floor board the part the old shift linkage is spot welded on
Old Dec 20, 2007 | 08:39 AM
skunked's Avatar
Default Re: H2B Question!?! (superfast666)
unless you hacked the **** out of the floor the two mounting points should still be on the floor to mount the OEM B linkage. You just need to seal it up with some factory sheetmetal from a donor car.
Old Dec 20, 2007 | 08:45 AM
Libertariat's Avatar
Ek Forever y0!
Default Re: H2B Question!?! (skunked)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">unless you hacked the **** out of the floor the two mounting points should still be on the floor to mount the OEM B linkage. You just need to seal it up with some factory sheetmetal from a donor car.</TD></TR></TABLE>
Old Dec 20, 2007 | 08:57 AM
skunked's Avatar
Default Re: H2B Question!?! (ek forever guy)
here are a couple pics I stole from Poison. As you can see the two mounting points are still retained.
Old Dec 20, 2007 | 09:29 AM
darkclark's Avatar
go to a junk yard and find a civic or integra that has had the body totaled and buy the body the cut out tunnel and replace a section of yours with it
Old Dec 20, 2007 | 09:30 AM
h-duced's Avatar
yeah i dont think i have those two mounting points anymore lol
scrubdakiller80
13
Jun 9, 2017 08:17 AM
1.8EG-T
Feb 7, 2015 03:44 PM
cashshoes
Aug 30, 2008 06:17 AM
blackjackEG
34
Dec 13, 2006 06:39 PM
Klimax
12
Nov 1, 2005 01:45 PM
