KICS wheel spacers....anyone using them??
Old Dec 19, 2007 | 10:27 AM
alscrx's Avatar
Default KICS wheel spacers....anyone using them??
Not sure if they are new but i have just seen then. They come in 4x100 and in most size mm's. They have studs in them already so you don't need extended ones. Anyone using these? Have pics installled?
I also wanted to know if our honda factory wheel studs have to be cut after installing spacer so they don't hit the wheel when installed!
Old Dec 19, 2007 | 12:15 PM
2ndlife's Avatar
Default Re: KICS wheel spacers....anyone using them?? (alscrx)
Some rims have spaces inside to allow for the studs. If you don't have enough space on the rims then you can not use the spacers. if you use the 25mm or thicker spacers, you won't have any problems with the studs hitting the wheels.
Old Dec 19, 2007 | 12:29 PM
alscrx's Avatar
Default Re: KICS wheel spacers....anyone using them?? (2ndlife)
Well i plan on using these with oem honda fit wheels
743power
182
May 19, 2017 07:30 AM
MugenEg
Dec 28, 2009 12:21 PM
bowflex21
Jan 27, 2007 01:34 AM
2-7offsuit
Suspension & Brakes
Nov 25, 2005 01:43 AM
