is a y8 obd1 or obd2...NEED HELP WITH MINI-ME...Head SWAP..
i am doing a mini me with a d15b7...is there any wiring i have to change..can i use the y8 dizzy...i need help with this...i hear its obd1 but others say its obd2..help me..
wat will be everything i need to do the mini me...here is wat i heard
use 8 b7 head stud and 2 y7 or y8
i can use the y8 dizzy also heard i should just use my b7...
OK..im just going to tell u my set up...
d15b7 block
d16y8 head
y8 intake mani
a6 piston or p29(oldschool integra)
y8 head gasket
thats about it..tell me other things i need..
d15b7 block
d16y8 head
y8 intake mani
y8 head gasket
You can re plug a y8 distrib to be obd1 or visversa they all have the same wires besically the sam distrib just diff plugs. If done it and the work the same 2 and its always good to use the same parts. Its not that hard to replug distributors or you can always dothe getto cut and splice
Assuming you stay stock bore, Y8 headgasket, no decking or milling, the pistons will be in the hole .0669" (A6 pistons). That will lower your compression to 8.8:1. A6 pistons are dished, B7 pistons are flat tops.
You can use your b7 dizzy, if you try using a z6 it won't bolt up the to y8 head, also i don't think the set up will run b/c i think the y8 dizzy has a crank position sensor in it. but not fully sure but i do know that the y8 dizzy will not run the mini-me.
Modified by mini-meEj1 at 9:58 PM 12/24/2007
also if you want to run high compression with pistions you should look into pm7 (zc) pistons...i think they still sell a kit on ebay wit the pistions and bearings and i think thrust washers
xwhitchx
Mar 23, 2009 01:59 PM
builthatch
Jan 25, 2004 09:49 PM
