b20 vtec help
im about to build my b20 vtec this week and ive been reading alot about clearance issues..and also about how much power this setup makes..im goin to be running a stock b20b block..stock pistons,arp rod bolts..or course vtec oil and water pumps..ls crank and ls rods..b16 head..pretty much fully worked..full port and polish,skunk 2 springs and retainers..itr headers..evo2 exhaust..comptech box intake..b16 tranny..stage 2 clutch..im plan on using skunk 2 stage 2 cams..so my question is will have clearance issues with these cams..if so what should i do..and about how much power will this setup make..please help..
do yourself a favor and dont run stock B20 pistons, if you're already installing arp rod bolts, The correct way of installing them is by removing the pistons/rods from the block anyways..why not just replace the pistons while you're at it....
nice set up, but why use ls rods and crank? They are identical just get the rods shotpeened and balanced. Stock pistons are fine. Just keep the RPM's below 8000. build your setup, get it tuned, and see the numbers
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda_ef9 »</TD></TR><TR><TD CLASS="quote">there will be piston to valve touch....i would tell you how to fix it but you prolly wont listen so yea good luck</TD></TR></TABLE>
really??
explain.
really??
explain.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lsvtec2000 »</TD></TR><TR><TD CLASS="quote">im about to build my b20 vtec this week and ive been reading alot about clearance issues..and also about how much power this setup makes..im goin to be running a stock b20b block..stock pistons,arp rod bolts..or course vtec oil and water pumps..ls crank and ls rods..b16 head..pretty much fully worked..full port and polish,skunk 2 springs and retainers..itr headers..evo2 exhaust..comptech box intake..b16 tranny..stage 2 clutch..im plan on using skunk 2 stage 2 cams..so my question is will have clearance issues with these cams..if so what should i do..and about how much power will this setup make..please help..</TD></TR></TABLE>
do ur self a favor and spend the xtra 300 bucks for some RS itr style b20 pistons, trust me you'll thank me later
C2K_TB_TEC
18
Mar 31, 2009 04:56 AM
