98 ls auto swap w/ 95 gsr manual
Old Dec 18, 2007 | 05:36 PM
boostedteg4dr's Avatar
Default 98 ls auto swap w/ 95 gsr manual
How do I swap the enging trans in both?
Old Dec 18, 2007 | 05:53 PM
chad's Avatar
Moderator
Default Re: 98 ls auto swap w/ 95 gsr manual (boostedteg4dr)
what is your question?
you are doing a conversion from auto to manuel?
Old Dec 18, 2007 | 10:27 PM
Default Re: 98 ls auto swap w/ 95 gsr manual (chad)
Im swapping the enging/trans on a 1998 ls auto with a 1995 gsr manual.
The 95 gsr will have the auto LS enging/trans.
The 98 LS will have the 95 gsr engine/trans.
Old Dec 19, 2007 | 08:34 AM
chad's Avatar
Moderator
sounds like a waste of time!
that is so reversed engineered it isn't even funny....
you might as well pull the dashes and swap out all the wiring too
Old Dec 20, 2007 | 12:27 PM
why do you ask questions stupid expletive
Old Dec 20, 2007 | 12:33 PM
chad's Avatar
Moderator
see....i'm a mod here.....
your questions were vague to say the least....
if i were in a really bad mood i'd dock you points and all....but i'm not like that....
you asked....
you are reverse engineering the whole thing....
it is way way too much work to go from a manuel to an automatic....i can see doing a auto to manuel....but the other way around is going to be too much work...
you are going to have to change all the pedals
all the wiring harness in front of the fuel pump....
change mounts.....
do you want me to go on???
i think i know what i'm talking about i'm not the guy who asked the question in the first place!!
Old Dec 20, 2007 | 06:57 PM
The reason Im doing it is because I have a built enine and trans in my 95 gsr in wisconsin. The body is in rough shape. I bought the 98 in california and it is in great shape. When all is done i will have a winter beater 95 with the ls and a 98 with the built engine and all.
Old Dec 20, 2007 | 09:06 PM
Bense's Avatar
if you're so set on it, why don't you just start pulling it apart and figuring it out.
Old Dec 20, 2007 | 10:50 PM
Default Re: 98 ls auto swap w/ 95 gsr manual (Bense)
cause the 98s in cali and the 95s in wisconsin....hmm
wow...this is some sweet advice....thanks guys.
Old Dec 21, 2007 | 04:13 PM
boostedcivicsir's Avatar
Mr. Badwrench
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedteg4dr &raquo;</TD></TR><TR><TD CLASS="quote">cause the 98s in cali and the 95s in wisconsin....hmm
wow...this is some sweet advice....thanks guys.</TD></TR></TABLE>
well thats quite the canundrum.
keep it tech, ask specific questions as to what you need.
by the looks of it you need both cars in front of you.
Aar0n
Apr 3, 2015 10:39 AM
crxsimike
Jan 30, 2006 07:22 PM
dn777
Aug 17, 2004 12:11 PM
acuraLSSE95
Jan 14, 2002 04:33 PM
