do i need a relay for viper 791xv
Old Dec 18, 2007 | 05:27 PM
winkwitstyle's Avatar
Default do i need a relay for viper 791xv
im installing the viper 791xv alarm with aftermarket door lock actuators. the alarm works fine but when i connect the door lock to the alarm and try to arm it the alarm doesnt send enought power to lock/unlock the doors. so do i need a relay for the door locks or is it built in the alarm it self or can it be that i install the alarm worng?
Old Dec 18, 2007 | 05:38 PM
B18C_EJ8's Avatar
Yes. You will need to use the lock module that came with the 791.
I'll be surprised if you haven't burned out the low-current lock/unlock outputs trying to drive aftermarket actuators directly.
Old Dec 18, 2007 | 05:46 PM
Default Re: (B18C_EJ8)
ehh funny thing is i never saw it in the box. bought the alarm second hand but unused.
Old Dec 18, 2007 | 05:47 PM
B18C_EJ8's Avatar
Then you'll need to use two relays.
Old Dec 18, 2007 | 05:53 PM
451m is the relay i need correct?
PS thanks for the replys.
Old Dec 18, 2007 | 06:12 PM
B18C_EJ8's Avatar
Yes. 451m is all you need. Contains two mini-relays.
Old Dec 19, 2007 | 10:45 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
What kind of car? You sure you tagged the right wires?
Old Dec 21, 2007 | 10:29 PM
Default Re: (JDM_Ej)
aftermarket locks install. i have the problem solved. bought relays.
chrisfromsrq
Audio / Security / Video
Jun 29, 2009 05:40 PM
ivanson
Feb 26, 2006 07:32 PM
ChillOutWayne
Feb 25, 2004 09:43 AM
tysf
Oct 26, 2002 06:04 AM
