ek sir clock.
Wire them to your dash harnesses. Match the wire colors on the plug and splice them to the same colors in your dash harness (ie radio harness, climate control harness).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenManR »</TD></TR><TR><TD CLASS="quote">i have the harness it comes with, its has 4 wires, were do i wire them too? </TD></TR></TABLE>
FIY, the clock didn't just come on the SiR.
For example, mine is from an EK3.
I wired mine to my radio harness so that I wouldn't cut into my dash harness.
For example, mine is from an EK3.I wired mine to my radio harness so that I wouldn't cut into my dash harness.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MugenManR »</TD></TR><TR><TD CLASS="quote">thank you i had it hooked up to my dash but it dosent work, none of my lights on my climate control work, dose anyone know why? </TD></TR></TABLE>
You're going to have to be more descriptive.
Did the lights work before the installation of the clock?
Did the lights work before the installation of another part, such as a radio?
Did the lights stop working after the installation of a particular part?
Did the lights ever work?
You might have popped a fuse while exposing the wire(s) if you didn't remove the negative terminal of the battery. Check your instrument fuse and your backup fuse (engine bay).
they worked on and off, like i tap the bottom of the dash and they would turn on, after the power window conversion, clock, and si radio it just didnt work competle other than the lights on the buttons not around them, also the buttons on my si radio dont light up, just the screen.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iKrizz »</TD></TR><TR><TD CLASS="quote">There's no plugin on the dash harness? There is in my EG..</TD></TR></TABLE>
USDM '96-'00 Civic don't come with the clock he's talking about. Our cars come with a clock on the radio.
silentdeath12886
May 19, 2008 11:09 PM
esteps
Sep 20, 2004 02:42 PM
