Timing belt?
I have a question
. Does any aftermarket company make timing belts for the H22A? I know a company from Japan named Power Enterprise has one for the B series motor. Do they have one for H22A? The thing is that I have a JDM H22A with Skunk stage 2 cams and a few other thing..., but the OEM timing belt looks pretty wear and I just change it not to long ago! (3 months)
Also the belt tensioner is not working properly (might be the problem). Do 2000-2001 prelude belt tensioner fits older H22A (JDM 95) I’m going to swap this engine to a hatch because some F*&$@# hit my car on the side bending the roof So I'm going to take this time to change the belt, tensioner, clutch and few other things... Should be fun. Thanks for your help
. Does any aftermarket company make timing belts for the H22A? I know a company from Japan named Power Enterprise has one for the B series motor. Do they have one for H22A? The thing is that I have a JDM H22A with Skunk stage 2 cams and a few other thing..., but the OEM timing belt looks pretty wear and I just change it not to long ago! (3 months) Also the belt tensioner is not working properly (might be the problem). Do 2000-2001 prelude belt tensioner fits older H22A (JDM 95) I’m going to swap this engine to a hatch because some F*&$@# hit my car on the side bending the roof So I'm going to take this time to change the belt, tensioner, clutch and few other things... Should be fun. Thanks for your help
Yeah but OEM timing belts for H22A aren't desing for over 8,000 rpm. My car still make power there, cams (Spoon program on a OBD-1 JDM ECU) and my fuel cut off is 8,500 rpm. I shift at 8,200 just to be safe!. I just ask because some people running Toba B, C are breaking their OEM timing belt because they can't handle the big lift or rpm of those cams. My cam are bigger than stock and the belt looks pretty worn in just 3 months. I just want peace of mind
