Radiator Nightmare!!
So in the process of changing the radiator, one of the damn bolt snapped half way. Now under pressure, it sqirts out coolant... Any advice on geting this screw out? The picture is of which bolt snapped, if you follow the top radiator whose ytoull get to it...
Modified by oovvutt at 5:56 PM 12/18/2007
I think you mean "bolt", theres no screws (we all hope) holding together your cooling system
That part shouldnt have to come out to change a radiator, but despite that, if it did break off, your going to have to have to take a tap/die kit to it to effectivly remove it. Otherwise let a shop take it out for you. Those things can be a bitch.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 97Ej6mike »</TD></TR><TR><TD CLASS="quote">I think you mean "bolt", theres no screws (we all hope) holding together your cooling system
That part shouldnt have to come out to change a radiator, but despite that, if it did break off, your going to have to have to take a tap/die kit to it to effectivly remove it. Otherwise let a shop take it out for you. Those things can be a bitch.</TD></TR></TABLE>
x2, Like he said, you shouldnt have taken off that screw to remove the radiator.
sometimes you can take a sharp chiesel and put the sharp corner of it into what is remaining of the bolt and tap on it so that it will eventually back out. If you do this soak it in PB Blaster so that whatever caused it to sieze can be broken loose.
