Suspension & Brakes Theory, alignment, spring rates....
What are your Ground control spring rates with Koni's?
Old Dec 18, 2007 | 10:43 AM
20ls01's Avatar
Default What are your Ground control spring rates with Koni's?
let me know what your using and your opinion on them...thanks
Old Dec 18, 2007 | 12:45 PM
artifex's Avatar
say it
Default Re: What are your Ground control spring rates with Koni's? (20ls01)
400 lbs/in front, 450 rear. 22mm rear sway. Can tune in rotation nicely using the shocks. I DD the car on the not-so-great Illinois roads so I didn't go to aggressive with the spring rates.
I've had the Konis for 6 years now with this setup and haven't had a problem.
Old Dec 18, 2007 | 01:11 PM
clem kevin's Avatar
im using 380 front, 300 rear. i wish i had gone stiffer on the springs and will probobly get another set at 400/400
Old Dec 18, 2007 | 07:02 PM
Targa250R's Avatar
be professional
This is a rather pointless thread, especially since nobody has yet even bothered to mention the vehicle they're using.
What sort of information are you looking to gather from this thread? Ask a question, and we can give you advice.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 20ls01 &raquo;</TD></TR><TR><TD CLASS="quote">can someone tell me how to adjust ride height on koni/gc's?</TD></TR></TABLE>
Loosen the allen-head pinch bolt on the spring perch, then thread the perch up or down on the threaded sleeve to set the desired ride height. Tighten the pinch bolt and you're done.
FastLife617
Suspension & Brakes
Mar 5, 2008 07:11 PM
Jeff99Base
Sep 26, 2005 06:54 PM
PrinceAli132
Jul 19, 2004 06:17 PM
The Punisher
Apr 19, 2002 07:12 PM
743power
Mar 20, 2002 07:25 PM
