skunk2 coilover
0700.025.006s and 0700.025.008s
could any1 tell me witch one are the front and rear?
I already check skunk2 website.
http://i12.tinypic.com/7xyampf.jpg
is this the right way to put the coilover??
gold ring at the bottom.
how hard is it to measure you height??
What kind of car? The ring does go on the bottom. You have the spring upside down; not sure if it really matters but why temp fate. As a quick guess I'm going to assume the 0700.025.008s are for the front and the 0700.025.006s are the rears. The 006 and 008 are the spring rates; 6kg/mm and 8kg/mm. I found this info on the Skunk2 website. The example I used isn't for your exact springs but I made an assumption based off the information I found. I'm assuming you made a typo with the 025 which might be 250. Thus your springs are 0700.250.008s and 0700.250.006s.
This might be your exact springs.
http://www.skunk2.com/installation/517-05-0740.pdf
Modified by mechanix619 at 10:47 AM 12/18/2007
lol the guy i bought it from said the 6k are the front and 8k rear.
Lucky i ask on here before i start messing up.
but thanks dude!!!
oh my car is a ek but the coilover came off a integra.
but thanks dude!!!
I could be wrong. I just looked at the picture again and it is 025 not 250, my bad. I've looked at two pdf's from Skunk2. One has the lower spring rating in the front and the other has the higher rating in the front. I would send Skunk2 an email.
http://i8.tinypic.com/8ebmnbl.jpg
here is a better picture.
i found another one on clubcivic
http://www.clubcivic.com/board...80836
Modified by immajackuup at 11:03 AM 12/18/2007
the 8k is 250 and the 6k is 025 for some reason but yeah imma install them right now with 8k front and 6 rear.
Modified by immajackuup at 11:14 AM 12/18/2007
hell yeah that skunk2 coilover ride so expletiveen smooth not even bouncy.
but how do the hell yall measure the height??
do i have to put it on a jack and take the stupid wheels off to??
redCJOteg
May 31, 2004 03:25 PM
Tyson
Nov 27, 2003 08:51 PM
006s, 008, 008s, 0700025006s, 0700025008s, 0700250006s, 0700250008s, 517050740, coilover, front, immajackuup, pdf, skunk, skunk2, spring, springs, witch
