H22 Ek swap..... FIRST START WONT START
Old Dec 18, 2007 | 08:12 AM
hatchbkdrvr's Avatar
Default H22 Ek swap..... FIRST START WONT START
So yeah i just finished my h22 swap into my EK and it wont start. It will turn but it wont start.
Im running a p72 ecu.
There are probably about 4 sensors which dont have homes but i figured they were just extras.
Any help is greatly appreciated.
What am i doing wrong?
Old Dec 18, 2007 | 08:24 AM
Ok so here are the sensors with out places to go
But i dont think these are supposed to go anywhere
Old Dec 18, 2007 | 10:35 AM
So no one can help?
Old Dec 18, 2007 | 10:52 AM
the CEL is throwing a code 15 ignition output signal
Old Dec 18, 2007 | 12:41 PM
Specail Ed's Avatar
Default Re: (hatchbkdrvr)
Have you searched for wiring diagrams yet? I'm sure you'll find something. It's kind of tough to tell from your pictures what goes where. Did you get an injector resistor? The one with the yellow cap looks like knock sensor, but not sure. Also look for OBD 2 to ODB 1 wiring.
Old Dec 18, 2007 | 12:46 PM
the knock sensor is already connected. But no i havent done the resistor boxfor injectors. I didnt think i had to nor do i know how to. I read the h22 faq section and it had a breif part about resistor box but all that went straight over my head, i didnt understand any of it.
Old Dec 18, 2007 | 01:23 PM
skunked's Avatar
injectors can be an issue if the motor has peak and hold injectors on it.
and your IAT is not plugged in (white sensor on the side of the manifold).
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hatchbkdrvr &raquo;</TD></TR><TR><TD CLASS="quote">
Old Dec 18, 2007 | 01:25 PM
yeah i forgot about that, i dont have one on my harness for that.... i thought that could be eliminated anyway with a tune.
Old Dec 18, 2007 | 01:28 PM
skunked's Avatar
nope, you need IAT.
How about thermostat, speed sensor, MAP, TPS? those all plugged in?
Old Dec 18, 2007 | 01:32 PM
yeah those are all there
Old Dec 18, 2007 | 01:37 PM
skunked's Avatar
well you need to do some more homework and list the colors of all the wires that aren't plugged in. Then list all the sensors that aren't connected to the harness.
Old Dec 18, 2007 | 06:59 PM
h22ek9forme's Avatar
Default Re: (skunked)
look at the motor and see what sensors are not plugged in, regardless if you need them or not,
then go from there
Old Dec 19, 2007 | 03:24 AM
high_revs's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skunked &raquo;</TD></TR><TR><TD CLASS="quote">well you need to do some more homework and list the colors of all the wires that aren't plugged in. Then list all the sensors that aren't connected to the harness.
x2....from there we can tell you possibly if anything needs to be extended..
some sensor you wont need to start the car, but your gonna need them after its running anyways.
Old Dec 19, 2007 | 05:40 AM
I need to extend my IAT and hook up the resistorbox.
tizzle4rizzle
Mar 7, 2012 06:43 PM
tizzle4rizzle
Mar 7, 2012 06:33 PM
peter17212
Mar 30, 2009 07:40 AM
hatchbkdrvr
Dec 18, 2007 02:11 PM
cates_07
May 10, 2007 11:37 AM
