Honda S2000 Honda S2000
Need welding diagram
Old Dec 18, 2007 | 02:18 AM
6SpeedFTW's Avatar
Default Need welding diagram
I need a diagram detailing all the weld points for the rocker panel, rear wheel well, and rear quarter panel. Any help is appreciated.
Thanks
Old Dec 18, 2007 | 11:46 AM
S@nt0s's Avatar
Munkyw3rkz.webs.com
Default Re: Need welding diagram (6SpeedFTW)
personally i would weld it as i see fit. i doubt you can get that kinda info but as a welder its a case by case basis he will weld it as he/she feels that its solid
Old Dec 18, 2007 | 01:13 PM
street_ruler's Avatar
Default Re: Need welding diagram (S@nt0s)
i think he is looking to cut it out at the spot welds
Old Dec 18, 2007 | 01:52 PM
6SpeedFTW's Avatar
Default Re: Need welding diagram (street_ruler)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by street_ruler &raquo;</TD></TR><TR><TD CLASS="quote">i think he is looking to cut it out at the spot welds</TD></TR></TABLE>
Exactly. I damaged my rocker panel and because of its position i need to remove the quarter panel also to remove it.
Old Dec 22, 2007 | 12:07 PM
SOHC_me's Avatar
you can see them if look close enough lol, just use a die grinder, or if you have a spot weld driller bit
Old Dec 23, 2007 | 08:30 AM
Mr. Projekt's Avatar
* B A N N E D *
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 6SpeedFTW &raquo;</TD></TR><TR><TD CLASS="quote">
Exactly. I damaged my rocker panel and because of its position i need to remove the quarter panel also to remove it.</TD></TR></TABLE>
Pick up an S2000 body repair manual. It's like $20, and shows you all the points of the spotwelds as well as cross-section measurements.
Old Dec 24, 2007 | 12:35 PM
6SpeedFTW's Avatar
Default Re: Need welding diagram (Mr. Projekt)
Do you know where I can find the manual? I have the service manual but it doesn't tell you much.
Old Dec 26, 2007 | 12:39 PM
6SpeedFTW's Avatar
Some help finding the manual Mr. Projekt or anyone else? I guess you're still on vacation, happy holidays.
Old Dec 26, 2007 | 12:47 PM
S@nt0s's Avatar
Munkyw3rkz.webs.com
had one but not anymore sorry....
MethodR002
May 14, 2007 07:44 AM
vizsual00
Mar 29, 2005 10:12 AM
JDMTegraKid
Jun 20, 2004 01:44 PM
ILOVEGIRLS
Jan 3, 2004 08:20 AM
dclub01
May 12, 2003 11:11 PM
