Some interesting formulas a few of you might like...
I
Math
Formulas
Rod ratio= Center line to center line length of the rod / Stroke
1.74 or greater is most desirable for racing
Air temperature = every 7 degrees F >60 degrees F= 1 % loss in
horsepower
CI displacement = bore x bore =__ x .7854 =__ x stroke: divide by .061
for CC x number of cylinders
Compression ratio: Volume of the cylinder, piston dish and head dish and
headgasket from top to bottom of the stroke, divided by the head, piston,
and headgasket volume or:
bore(in.) x bore(in.) =__ x .7854 =__ x stroke (in.) =__/ .061=__cc of
cylinder + (head cc +piston cc + headgasket cc) / (head cc+ piston
cc+headgasket cc) = compression ratio
Piston speed in fpm= stroke (in.)x rpm/ 6
Piston speed desired= 5800 fpm or less
Horsepower= rpm x torque/5252
Altitude effects on HP: every 1000 ft + = 3% loss in HP
Engine CFM approximation: RPM x C.I. displacement / 3456 = approximate
CFM: Example, Civic 1.6, 97 C.I x 7200 RPM = 698400 / 3456 = 202
approximated CFM
Calculation for CFM from HP: HP x .5 (BSFC) = __lb. per hour fuel x 13.2
air/fuel ratio = __lb. air per hour / 60 minutes per hour = __ lb. per
minute / .07 = CFM. Example: Civic 1.6, 127 hp x .5 = 63.5 lb. per hour
fuel x 13.2 air fuel ratio = 838.2 lb. air per hour / 60 minutes per hour
= 13.97 lb. per minute / .07 conversion to CFM = 199 CFM
Injector flow increase vs. fuel pressure increase:The square root of the
new fuel pressure / original fuel pressure x the original fuel injector
flow =__ new flow in lb. per hour: Example 1.6 liter Civic with Auxiliary
Fuel Pressure Regulator: Take the square root of 70 psi(new rail
pressure) / 40 (original rail pressure) = 1.3229 x 24 lb. per hour =
31.75 new flow rate in lb. per hour
Injector sizing for horsepower: Desired HP x .5 (BSFC)=__ lb. of fuel
required for desired HP / __amount of injectors =__lb. per injector x
__duty cycle = __lb. per hour per injector
Fuel pump or injector horsepower capability = Pounds per hour@fuel
pressure desired x 2 =__ HP capability
Gallons per hour to Pounds per hour= __ gallons x 6=__Lbs per hour
Math
Formulas
horsepower
approximated CFM
This is greek to me
Btw, this is part of the "tech seminar" that Oscar will be giving this Sunday at my event
. I just read the whole presentation and it`s really informative.
Ryan
[Modified by vtecvoodoo, 12:00 AM 6/28/2002]
. I just read the whole presentation and it`s really informative.Ryan
thecruzs2007@yahoo.com
Sep 27, 2009 12:08 PM
Nice_Dc2r
Jun 8, 2003 11:44 AM
vtecvoodoo
30
Nov 10, 2002 10:35 AM
shi - whose FAQ'ing this thread already
