looking into head work!
I am looking into head work to see who's offering the best job for the money. I was wondering how you all feel about head work and not having something like K-pro to work with. I would just like to get some feedback and pro's and con's from you all. thanks guys. this is a KMS package Head Porting - Stage 1
Price: $475 | 770.652.3538 | Have Us Contact You
Products Included in the Stage 1
Cylinder Head
Services Included in the Stage 1
Mild Port Job
Glass Bead
Fly Cut Head
Valve Job
Note: Price does not include seals or Shipping & Handling
Here you can see some of the features of our cylinder head service.
All casting marks in the air ports are removed to help increase airflow speed. The head is ported, polished, and glassbeaded to smooth out all minor flaws.
Depending on stage, you also receive race valve job with 5 angle intake 3 angle exhaust. The head is also flow tested in house on our flow bench. The final step is to deck the head by flycutting it. During this step, increased compression is available.
Head Porting - Stage 2
Price: $700 | 770.652.3538 | Have Us Contact You
Products Included in the Stage 2
Cylinder Head
Services Included in the Stage 2
Mild Port Job
Glass Bead
Fly Cut Head
Valve Job
3-Angle Valve Job
Popular Stage 2 options are available for an additional cost:
Staleited Nitrided Valves
Aluminum or Titanium Retainers
Silicone Bronze Valve Guides
Racing Springs
Custom Ground Cam
The picture above show some of the features of our Stage 2 cylinder head service.
Notice the opened intake and exhaust ports that are matched to the gaskets.
The head is ported, polished, and glassbeaded to smooth out all minor flaws. The head is flow tested on our in-house flow bench. Finally, the head is flycut. We can increase compression to your specs.
Head Porting - Stage 3
Price: $1000 | 770.652.3538 | Have Us Contact You
Products Included in the Stage 3
Cylinder Head
Services Included in the Stage 3
Extreme Port Job
Glass Bead
Fly Cut Head
Valve Job
Gasket Matched
Valves Lightened
New Radius on Valves
Extreme Reshaping of Valves
Popular Stage 3 options are available for an additional cost:
Titanium Retainers
Race Valve Springs
Custom Ground Cams
Brands include Skunk2, Comptech, Ferrea, Web Cams, Crower, Crane.
Cylinder Head
Mild Port Job
Glass Bead
Fly Cut Head
Valve Job
Cylinder Head
Mild Port Job
Glass Bead
Fly Cut Head
Valve Job
3-Angle Valve Job
Racing Springs
Custom Ground Cam
Cylinder Head
Extreme Port Job
Glass Bead
Fly Cut Head
Valve Job
Gasket Matched
Valves Lightened
Titanium Retainers
Race Valve Springs
Custom Ground Cams
I was hoping that Mr NOTE would have a thought for me. being that you track your car and you have some good input from being at the track and seeing what other have done with si's. would you think about getting some headwork done?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamanforlife »</TD></TR><TR><TD CLASS="quote">I was hoping that Mr NOTE would have a thought for me. being that you track your car and you have some good input from being at the track and seeing what other have done with si's. would you think about getting some headwork done?</TD></TR></TABLE>
What I said above your previous comment makes perfect sense. How do you expect your car to run correctly with headwork? The computer can only compensate for so much. Its very possible to have your car run worse and produce lower numbers than it did before the work you are asking about.
Definitely wait until there is some kind of good management out for us. Im not trying to bum you out, but you could spend that money in a better area right now seeing as the headwork/porting etc would not be the best choice without tuning.
I have a injen CAI, throttle body spacers and heat shield along with LSD 60mm cat back. im just trying to setup for the next step. header, cams, head work. im waiting on the re flash to see whats to come from HONDATA. not sure what else to do at this point, clutch, lighter flywheel, pulleys??? thanks again
OP. can't really do much with the extra airflow of headwork without tuning (like everyone already said)
Some companies do work with Hondata for custom reflashes. Comptech does for their supercharger. And Hytech does for their NA applications. They also make some of the finest headers money can buy. If your set on having headwork done, call them. If you just want to get a header, call them.
http://hytechexhaust.com/
btw. Do you have any experience with KMS?
They're in my area and I've been to their shop / manufacturing facility. The parts are pretty good for inexpensive parts, but I'm not sure about their machine work. I don't really have any experience with that part of their business.
NO I have not used KMS and that was another ?? . I have a guy around my way that does stuff ECR racing. actually there is a bunch of people in Baltimore that does machine work. I was thinking N/A so Im waiting like everyone else for fuel management. thanks
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondamanforlife »</TD></TR><TR><TD CLASS="quote">I have wheel and tires thay rub under heavy cornering. I work @ the port of baltimore and the roads are bad so I am holding off on the tein setup for now.</TD></TR></TABLE>
If your rubbing with a stock suspension you may want to think of a different tire/wheel setup.
yea that's been a problem from the get I have 8x 18 wheels and they should have been 7.5x 18. I went Thu some stuff with tread depot and it never got fixed. I just live with it, its a little rub on the inside plastic up front so its not to serious but it is a issue. im going back to stock so I might just sell them.
TurboSam
May 22, 2004 02:43 PM
