Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
What to lubricate latches and hinges with???
Old Dec 17, 2007 | 04:20 PM
JimmyM86's Avatar
Default What to lubricate latches and hinges with???
I'm sure there are many products out there that will be sufficient (WD40, white lithium grease. etc...), but what is recommend (or the best) for our cars?
Thanks!
Old Dec 17, 2007 | 04:26 PM
em2power's Avatar
Default Re: What to lubricate latches and hinges with??? (JimmyM86)
WD40 ftw!
Old Dec 17, 2007 | 04:43 PM
awang's Avatar
what I'VE heard, is lithium grease is what you want for lubricating... wd40 helps remove rusty bolts and stuff. afaik, wd40 attracts a lot of dust/grime
Old Dec 17, 2007 | 04:51 PM
JimmyM86's Avatar
Default Re: What to lubricate latches and hinges with??? (awang)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by awang &raquo;</TD></TR><TR><TD CLASS="quote">what I'VE heard, is lithium grease is what you want for lubricating... wd40 helps remove rusty bolts and stuff. afaik, wd40 attracts a lot of dust/grime</TD></TR></TABLE>
This is what I've always heard/done too...clean with wd40 (only if really dirty, then wipe off) and then lube with lithium grease. I was just wanting to make sure things haven't changed and I was doing this correctly.
Arigato Gozaimasu!
Old Dec 17, 2007 | 08:46 PM
toyomatt84's Avatar
Sanji
Default Re: What to lubricate latches and hinges with??? (em2power)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by em2power &raquo;</TD></TR><TR><TD CLASS="quote">WD40 ftw! </TD></TR></TABLE>
WD-40 is almost worthless. It's best at oiling your tools when you're done using them, if you don't have anything better to use. It's 80% water.
Lithium Grease is for lubricating metal on metal contact. And PB Blaster is a solvent for rusted bolts/stuck parts.
mikeycivic
Paint and Body
May 3, 2007 05:30 AM
Fo-Do Fanatic
Mar 29, 2007 07:20 PM
Takumi Fujiwara
Audio / Security / Video
30
Jan 8, 2006 09:15 PM
h22a193
Jun 20, 2004 05:02 PM
Sephro
May 9, 2003 04:58 AM
