B20B SWAP 99 Hatch DX
what year of ecu can we use? and we looked at the dx harness thats already attached to the car and it has only 8 wires the LS has 9..and the on the driver side plug only has 1 and the LS has 3..
make sure the harness off the dx can plug into the engine like injectors and sensors it should have all of that. What LS harness are you using an OBD1? I know my hatch uses the plugs on the driver side i converted my b20b to obd1 and used my original harness from the d series... just switch sensors and dist. use your injectors and intake other than that it should work
Modified by SMOOTHN at 8:25 PM 12/17/2007
ef8jdm
Aug 13, 2008 04:05 PM
happyabortion
Sep 17, 2006 06:43 PM
b18crxturbo12.1
May 1, 2006 01:24 PM
teefunk01
Mar 29, 2005 07:09 PM
