FULLY BUILT GSR SLEEVED BLOCK(AEBS SLEEVES) W/ CNC B16 HEAD(ALL BRIAN CROWER PARTS)
I HAVE A FULLY BUILT LONG BLOCK FOR SALE. ONLY SERIOUS BUYERS ONLY NO FLAKERS....!!!!!! I HAVE A LOT OF MONEY INVESTED INTO THIS SETUP, AND THOSE OF YOU WHO HAVE BUILT MOTORS BEFORE KNOW WHAT IM TALKING ABOUT..
I ONLY HAVE PICTURES UPON REQUEST TO PEOPLE THAT ARE POTENTIAL BUYERS.
THE MOTOR ISN'T COMPLETE DUE TO FUNDING BEING TIGHT. I GO TO SCHOOL AND NEED THE MONEY TO PAY OFF STUDENT LOANS. IF YOU HAVE ANY QUESTIONS YOU CAN REACH ME AT 732-773-8110. OR EMAIL ME AT ITALNSTALLION81@AOL.COM.
I HAVE RECIEPTS FOR MOST OF THE STUFF. ASKING $ 7000 OBO
GOODIES:
BLOCK:
GSR BLOCK BORED 84.5MM
AEBS SLEEVES WITH COPPER O-RING
ARP HEAD STUDS
COMETIC 84.5MM HEADGASKET
BRAND NEW TYPE-R OIL PUMP,WATER PUMP, TIMING BELT TENSIONER
EAGLE RODS WITH ARP 2000 ROD BOLTS
CP 9:1COMP. 84.5MM PISTONS WITH RINGS, WRIST PINS, AND LOCKS
EAGLE CRANK LIGHTENED
ACL RACE CHAMFERED BEARINGS
GSR MAIN CAPS WITH GIRDLE.
ARP MAIN STUDS
JDM GSR OIL COOLER WITH BRAND NEW OIL FILTER
BRAND NEW WINDAGE TRAY AND OIL PICK-UP
BRAND NEW MOROSO OIL PAN WITH OIL DRAIN LINE FOR TURBO
ALL BRAND NEW SEALS AND BOLTS
NEW ALTERNATOR BRACKETS AND OBD2 ALTERNATOR W/ NEW BELT
HEAD:
B16 HEAD CNC MACHINED BY M2 RACESYSTEMS IN NORTH JERSEY
BRIAN CROWER 1MM OVERSIZED VALVES
BRIAN CROWER DUAL VALVE SPRINGS 10,500 RPM LIMIT
BRIAN CROWER TITANIUM RETAINERS
BRIAN CROWER STG.2 TURBO CAMS
SKUNK2 ADJUSTABLE CAM GEARS (BLUE)
VALVE COVER HAS BEEN POLISHED AND HAS EARLS -8AN FITTINGS WELDED ON FOR BREATHER TANK WITH 90* FITTINGS ATTACHED.
NGK 7 PLUGS WITH NGK PLUG WIRES
OBD2 DISTRIBUTOR
GOLDEN EAGLE CAM SEAL
bump this if you view... somone wants a built motor capable of making 900whp...
i also have a full turbo setup top mount kit minus turbo. with full 4" aluminum exhaust... let me know.
its all about tuning.. if you have a built motor you would know.. and thats what eagle rates these rods at anyway. bought a kit direct from eagle. you interested in the motor? if not keep the comments to yourself.
900WHP+FWD=LIMITED TRACTION!
Just expletiveing with you haha. Sounds like a sick *** build and with the right turbo setup and proper standalone and tuning 800+ on this setup is VERY, VERY, capable. Good luck with the sale man.
thanks alot.... im actually debating weather or not to finish it.. i have a full turbo setup as well full 4" aluminum exhaust, topmount mani. tial 44, gt40r, etc... i mean im almost there, but i could also use the cash.. but thanks again for the compliment..
what a squabble you find yourself in huh? hey im over here
when your ready to sell me what i need. i still say i bring over some
and we put this thing together, but hey its on you..
