Differ Intake Manifolds???
Old Dec 16, 2007 | 07:50 AM
ShortyzKustomz's Avatar
Default Differ Intake Manifolds???
Ok, After a lil cussing I got my intake mani off to replace it with one I got off ebay. Mine had a crack so I got another stocker, I got it off and started switching everything over and I have a problem, On the back right corner there is a bolt hole going down and a vacuum port lower on the intake, On my new one there isnt. My old intake is labeled PO8-HF3 My new one is PO8-HF5, What do I do?
PS I need this driving by tomorrow for work
Old Dec 16, 2007 | 07:52 AM
97Ej6mike's Avatar
any pics?
Old Dec 16, 2007 | 09:07 AM
Pics are coming, Im not at home and stuck on dial-up been trying to get these pics up for an hour
Old Dec 16, 2007 | 03:27 PM
Default Re: (97Ej6mike)
Yes heres pics.. The old pic still has everything right around there attached, The new one is the powdercoated one with no bolt hole and no vacuum port on the bottom. I dont mind capping things to get it back to running good, whatever I need to do...
Theres 2 pics, Its the bolt hole holding that on and the vacuum port on the bottom, Thats just a purge valve right? Can I just cap it back at the canister?
Heres the new one no bolt hole or port
Modified by ShortyzKustomz at 4:40 PM 12/16/2007
Modified by ShortyzKustomz at 6:48 PM 12/16/2007
Old Dec 16, 2007 | 03:46 PM
Bump.. Anyone know if I can do away with that! I need to know tonight
Old Dec 16, 2007 | 04:15 PM
riceburner700's Avatar
Default Re: (ShortyzKustomz)
i would just run the vacuum hose to a hose on the front of the manifold like for the fpr and attached the black evap thingy to your firewall and plug it in along with running the other hose to your evap canister. should work just fine
Old Dec 16, 2007 | 04:41 PM
So your saying T it into another line and just zip tie it hidden out of the way?
Old Dec 16, 2007 | 04:51 PM
ejoner's Avatar
Yeah you bought a jdm d15b manifold that has no tapped hole for the evap purge solenoid to mount to and it also doesn't have a nipple for the solenoid to be plugged into to. Its simple tho you can either drill and tap that little nub that sticks out the manifold and then just use a T- fitting to get a vacuum source from another line on the manifold, or you can make another bracket to hold the solenoid either way all you need is a t-tap.
Old Dec 16, 2007 | 05:04 PM
Thanks again guys, HT always to the rescue, I shouldnt have any other problems with the manifold should I? Runners ports etc are all the same? No other problems on my Z6? I called off work tomorrow to get it all back together
Old Dec 16, 2007 | 06:53 PM
So this intake will work?
T-Knock
Honda Civic (2006 - 2015)
Sep 21, 2010 07:20 AM
mooseheads36
17
Nov 23, 2006 06:35 PM
pbizzlegsr
Jul 14, 2004 11:02 AM
DC5RK20A
Feb 26, 2004 07:23 PM
BrandonClaps
May 22, 2002 07:48 PM
