Honda G23 Engine
Hello again i have a 98 honda accord sedan with an f23a1 and just came across a 94 prelude with and h23a1 the body is unsalvageable and was wondering if it would be to my benefit to swap the motor into my accord what kind of modifications would i have to do and also was wondering if the head swap would be beneficial, i have read pirates head swap and was wondering if you have to bore it out to get good compression
i'm not sure about the head swap or any of that but i just finished an h22a4 into a 98 accord four door, and i had to do alot of fabricating, i had to cut away some of the crossmember on the front drivers side, had to fabricate the driverside motor mount, big up to rywire they built the harness for me, i'll just say good luck on what ever you do cause we had the car down for 5 weeks. but i definitely learned alot and the car is pretty quick for being a sled! we kept up with a b16 eg and had 3 people in the accord, not too bad in my book! best of luck to ya man , if you need any help just send me a message
if you read all of pirates head swap thread, then you probably know enough about the head swap to make your own decision on it.
none the less, yes, it would be beneficial to swap the head
