Suspension & Brakes Theory, alignment, spring rates....
quick question on camber kits
Old Dec 15, 2007 | 09:16 PM
vlc92189's Avatar
Default quick question on camber kits
my car is lowered, and its eating the inside of the tire. so im going to get a front and rear camber kit. is there a difference between these two? if so what? and what one is better?
this is a front camber kit and a rear shim kit?
http://cgi.ebay.com/ebaymotors...ZWDVW
and this is front and rear camber kit
http://cgi.ebay.com/ebaymotors...wItem
Old Dec 15, 2007 | 10:19 PM
1988_96hb's Avatar
Default Re: quick question on camber kits (vlc92189)
on 92-00 civics you can make a diy rear camber kit by adding washers to the bolts where an aftermarket camber kit would go heres the link to the DIY rear camber kit:http://home.earthlink.net/~civ....html
Old Dec 15, 2007 | 10:23 PM
1988_96hb's Avatar
you can make your own shim kit for less than $5. the omni front camber kit looks like a knock-off of the skunk2 camber kit. which is very good IMO. have had my skunk2 camber kit on my ek for close to a year no problems
Old Dec 17, 2007 | 11:57 PM
vlc92189's Avatar
Default Re: quick question on camber kits (1988_96hb)
well is the shim kit like the washers you was talking about?
anyone else?
Old Dec 2, 2010 | 04:04 PM
smartguysjt's Avatar
what happens if you strip the bolts where you are trying to installed the longer bolts....how do you get it out or what can i do...i need HELP
Old Dec 2, 2010 | 04:36 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
You stripped the bolts, or stripped the welded nuts on the other side of the metal where the bolts go into? Are the bolts stuck in the holes?
Old Dec 3, 2010 | 12:28 PM
yes the bolts are stuck in the welded nuts on the other side of the metal and that's why the bolt doesn't want to come out also...http://www.nostreetracing.org/forums...431#post373431
Conclusion
Suspension & Brakes
24
Aug 28, 2008 05:13 PM
jeison
Jun 9, 2006 12:16 PM
kseriesDC5
Sep 1, 2004 07:11 AM
