spring rates vs sway bar diameter
I drive hill and circle race's, hole year I'm on D2 coil overs f13/r7 and original front sway bar 23mm and 15mm rear, the car is relative neutral and turn good but I think the reason for that it's because I'm slow
I think there is some connection between spring rate and sway bar diameter.For example, high spring rate whit original sway bar or opposite way? What do you think? Sorry I forgot, my race car is civic EG6 which weight 900kg=1980lbs and it's on slick tires.
It's not a problem I will buy other springs, I saw the topic for spring rates and I notice that some prefer 10f/14r setup. What do you think with disconnecting? You mean to drive with 20mm sway bar or slimmer? Than why they put bigger sway on ITR
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PRKI-VTI »</TD></TR><TR><TD CLASS="quote">It's not a problem I will buy other springs, I saw the topic for spring rates and I notice that some prefer 10f/14r setup. What do you think with disconnecting? You mean to drive with 20mm sway bar or slimmer? Than why they put bigger sway on ITR </TD></TR></TABLE>
Reverse the spring and see and disconnect I think you will like it.
I think try 500lbs in the front then keep the 14 in the rear it should be more fun.
They put the bigger in the front so people don't kill themselves.
You can try smaller bar in the front but put everything bigger in the rear.
EK4civichatch
25
Sep 12, 2015 03:34 PM
Falloutkid90
14
Jul 21, 2015 05:31 PM
EMphaticONE
Nov 17, 2004 09:21 AM
ion_four
Apr 20, 2003 08:45 PM
