kaaz lsd install stock vechile sensor does not go in
Old Dec 15, 2007 | 12:43 PM
drift2004's Avatar
Default kaaz lsd install stock vechile sensor does not go in
hey i bought a kaaz lsd from a friend of mine for a gsr, , i can not get the stock vechile sensor the rod to go in fully, do i need from the kaaz, or what? heres a pic of the stock one, so my question is do i need a different one?
Old Dec 15, 2007 | 12:53 PM
97Ej6mike's Avatar
You sure everything's seated properly since you installed the part? From my experience, the gear that holds the differential can be a little tricky when re-assembling a tranny in terms of getting everything to line up first try.
Old Dec 15, 2007 | 12:54 PM
drift2004's Avatar
Default Re: (97Ej6mike)
i check the clearence and it was fine
Old Dec 15, 2007 | 03:14 PM
blk92_d16's Avatar
The plastic gearing on the LSD cannot be put on upside down can it? or did you never tear down the unit?
Old Dec 15, 2007 | 06:36 PM
drift2004's Avatar
Default Re: (blk92_d16)
it did mess it up
EKweezy
Nov 25, 2010 08:42 PM
drift2004
Dec 17, 2007 10:46 AM
drift2004
Dec 15, 2007 09:58 PM
Anotherslo1
May 25, 2005 07:42 PM
