Accessory belt tensioner removal on 98 accord v6
Old Dec 15, 2007 | 11:53 AM
jt1583's Avatar
Default Accessory belt tensioner removal on 98 accord v6
Ok so my brother thought the alternator was bad on his accord, turns out the belt was broken. So i put on a new belt and it starts to melt and smoke and turns out the accessory belt tensioner pulley was stuck, causing the belt to rub raw on it and melt away.
I removed the two belts securing the tensioner assembly but I still could not pull it off. I hammered it from the bottom and it seemed to rotated but I still can't get it off. I found a picture of a replacement one and there is a large hole in the back center. I'm guess there is some kind of rod that goes into the tensioner assembly from the block for more support.
The car has ~180,000 which is probably causing some of the stubbornness, but this is ridiculous. How do I get this thing off? Btw, it is very tight in there, fwd engines are no fun to work on that side.
here is the pic
Old Dec 15, 2007 | 08:08 PM
jt1583's Avatar
Default Re: Accessory belt tensioner removal on 98 accord v6 (jt1583)
anyone know? if i don't figure this out by tomorrow i'm probably going to take it to a shop
Old Dec 15, 2007 | 11:36 PM
jt1583's Avatar
picture of the tensioner on car
Old Dec 16, 2007 | 01:49 AM
-RedneckDave-'s Avatar
Working
I believe there is a bolt running through the middle of it as well. I would check mine, but it is snowing outside.
Old Dec 16, 2007 | 05:46 PM
zeroice's Avatar
well to take the pulley off you have to undo all the motor mounts and jack the motor up about 6 inches to take the pulley off to get the bolt out so it doesnt hit the side wall and remove it.
techsupport
Mar 29, 2017 08:43 PM
famfive
Jul 25, 2010 08:29 AM
bds34
Sep 5, 2008 09:01 PM
jt1583
Nov 22, 2005 03:49 PM
patastinky
Mar 23, 2004 07:32 AM
