does any one have a picture of an ep3 with mini wheels
i almost bought a BARELY used set (but i found a better deal)
they say they are supposed to fit, but i havent seen anyone else with them on...
MINI WHEEL SPECS-
Bolt pattern is 4x100. Centerbore is 56.1mm.
The Cooper S comes standard with the R84, also known as X-Lite. It has a reasonable weight of about 18lbs. It's a 16 x 6.5 wheel, with a offset of 48
from the sport package, you get the R85, also known as the S-Lite. It's not light, though, weighing in around 25lbs. It's a 17 x 7;, with an offset of 50
Then there's the R90, which is a dealer option. It's made by BBS. It weighs around 24lbs. Also a 17 x 7 offset is 48
Hope this helps
MINI WHEEL SPECS-
Hope this helps
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by phthalo »</TD></TR><TR><TD CLASS="quote">those would look nice, especially the ones that look like wantanabe's or something. I don't know the specs on them though</TD></TR></TABLE>
those are the ones I am interested in but I have yet to see a pic of them on an EP3. I might just bite the bullet and get me a set.
I think they might fit after seeing this
since most wheels are pretty much universal on hondas this proof it might work. but I still cannot find any pics of an ep3 with them.
They'll fit. The offset between the EP3 and the Mini is close enough. As long as the hub bore is ok (which it appears to be, but that's uaually easily fixed).
