For a B16 motor, what will give you the most HP per $?
What will give you the most HP per $ on a B16A?
What amount of horespower are you guys talking about though. Obviously with a turbo you could get some serious gains, but what about those bolt-ons?
[Modified by bigphatcrap, 3:27 PM 6/27/2002]
I am just looking for the most bang-for-the-buck. I am not looking to rig my whoopty up, but I would like to get something extra out of my car. I know that you can have "too much" horsepower and then you have all types of issues, i.e. drivability, traction, etc.. I know that it can be, plain and simply unpractical. But then again, that is not what I am looking for. Just want some extra HP
Thanks,
BigPhatCrap
HP
Torque
Criminals
.Thanks,
BigPhatCrap
HP
Torque
Criminals
for the test pipe! haha, same here!
CTR intake cam, i netted 10whp from 1 cam!
dyno session,+ cam gears (better get I/H/E first though)
If your only looking to do one or two mods get nos. If you want to build the motor up start with I/H/E like KAMin said
[Modified by stuckatworksi, 8:36 PM 6/28/2002]
test pipes-
you don't gain anything you wouldn't over a good flowing cat.
and then the import community complains about 'gas guzzling' v8's polluting the environment.......ironic, isn't it?
you don't gain anything you wouldn't over a good flowing cat. and then the import community complains about 'gas guzzling' v8's polluting the environment.......ironic, isn't it?
00 ITR cams
good mod , drop in ---- just dont raise the redline from stock on THAT valvetrain
Great mod is Stock intake pipe if SI and Comptech Ice Box, Dc JDM header 2.5 collector (cheap) carsound 2.5 cat, Apexi N1 exhaust, Unorthodox racing crank pulley and other pulleys and 00-01 ITR cams and VAFC and some tunning makes good cheap HP and you will have fun. Also since the B16 is touque less a JDM final drive or ATS will help you out on the low RPM range and a LSD helps out a grip as well in handeling and launching.
Just my .02
CHRIS
Just my .02
CHRIS
hYbRiD EeEkAy
Jul 9, 2005 04:36 PM
reccommends nitrous for its cheapness, but still is N/A.
