any alternatives to running k-pro for my swap?
except the type-r ecu................................there is a specific reason i want to avoid the company in question. i do not mind doing more work, or even taking the cost of the product and going motec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic.slow »</TD></TR><TR><TD CLASS="quote">except the type-r ecu................................there is a specific reason i want to avoid the company in question. i do not mind doing more work, or even taking the cost of the product and going motec
Hondata was able to crack into the flash capabilities of the K-ECU's why not do some digging/research and figure out how to do this yourself? Start a whole new DIY movement.
</TD></TR></TABLE>Hondata was able to crack into the flash capabilities of the K-ECU's why not do some digging/research and figure out how to do this yourself? Start a whole new DIY movement.
after reading the accord project on pgmfi
i found out so far is that:
OKI 66Q592 is not fround but rather a 64F7055 is a Hitachi (Renesas) cpu is found in its place. there is no internally built programn to dump the rom
talk about this DLC cable is around
rom's are aval to download from a site that requires a 300 dollar annual mebershiip fee, supposrts all aplicable honda/acura cars.
i also found this:
37820-RBB-A54
2004 tsx auto ecu
7055 based
Mfg by Matsushita, different board layout
37820-PRB-A13
2005 rsx-s ecu
7058 based
Mfg by Keihin, very similar board layout to the accord ecu
honda epc states ecu part number 37820-RAD-A54 as a rewritable unit.
all ecu'sabouve 2002 are re-writable.
RAA bin is relased, i do have a copy will not hesitate to email to anyone who is interested in this project.
the rom dumper programn and souce is relased.
i also found this:
37820-RBB-A54
2004 tsx auto ecu
7055 based
37820-PRB-A13
2005 rsx-s ecu
7058 based
so basically to mod an ecu you need to
dump the rom (very close to being able to do this)
modify the rom (im sure this is the easiest part for a programmer, already has the RAA.bin dissassembeled on xenocron's site)
reload it back onto the ecu (which is done by the handheld unit that honda has, still unkown what code enables rom burning inside of that processor).
thats tuning in a nutshell. so they are pretty close and it was quite a breakthrough.
however they have only figured this out on the accord ecu's not the diffrent boarded ecus
but i belive hondata k pro is only aval. to rsx ecu's 02-04 prb if i rember am i correct?
Modified by civic.slow at 5:53 PM 12/16/2007
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch »</TD></TR><TR><TD CLASS="quote">k-pro is now available for all the k-series. accord, element, rsx, tsx, etc</TD></TR></TABLE>
butnot for 05+ ecu's right?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Garage 808 Hatch »</TD></TR><TR><TD CLASS="quote">ya, i think just up to 05</TD></TR></TABLE>
nice, you see how close these guys at pgmfi are?
they have all the .bins from the him, which has all the bins for north american hondas just in case a map needs to be reloaded, they also figured out how to run the programn that EDITS the .bins on their computer.
just no code to get it from the PC to the computer
(apperantly honda put some stuff where it sends a number to the ecu and expects a number back to make sure it is dealing with an authorized unit. after that DIY reflashes WILL be avalible!)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civic.slow »</TD></TR><TR><TD CLASS="quote">except the type-r ecu................................there is a specific reason i want to avoid the company in question. </TD></TR></TABLE>
since you put this in your thread for a reason, i assume you want us to ask you why you dont want to deal with them. so why?
Landon
Landon
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boosted_dc2 »</TD></TR><TR><TD CLASS="quote">since you put this in your thread for a reason, i assume you want us to ask you why you dont want to deal with them. so why?
Landon</TD></TR></TABLE>
no comment
no comment
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Seminole »</TD></TR><TR><TD CLASS="quote">well i'd be interested in knowing seeing i just bought their s300j</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by thehatchninja »</TD></TR><TR><TD CLASS="quote">probably because they shut pgmfi.org down</TD></TR></TABLE>
can we keep this in the direction of finding a solution for my tuning woes?
so i got a few more .rwd files from the HIM rip, im still trying to figure out the install/map edit that someone has aldready beaten me to. its going pretty smoothly, after all im just learning what the others did before me trying to figure out what 8 diffrent people figured out trying to put it together in an organized fashion. since that website is pretty much dead
its isnt shutdown i can still sign in with no problems?if it does get shutdown we can thank hondata for that.there just pissed cause we can do DIY tuning and not buying there overpriced b/s
can we keep this in the direction of finding a solution for my tuning woes? </TD></TR></TABLE>
why did you even bring up hondata in the first place then?
Landon
Landon
ok so i got the programn running FINALLY but when i try to import the RWD files it says
error, DLC port unconnected, when i hit abort it seems to do ok, then i try to import it again, then it says select language with a scroll down bar.....with nothing, everything else is jumbled numbers.
this is the programn found in HIM that allows you to F.UCK with the MAPS
some loaded up a regestry for the progreman i will check it out see if i can make mine look like his LOL
so now im finally only 5 days behind
figured out that :
will @ hybrid is making a new harness so he can test one of the DIY reflashed ecu;s on his motor
and type-r has already stated that te .rwd ripping programn from the actual ECU had a few flaws in it, that made inconssitent diffrences in each map.......however ALL of the HIM .rwd's are fine.......these are the legit ones from honda
figured out that :
SkyLinER
10
Sep 30, 2004 10:02 PM
2005, 37820prba13, 37820rada54, 37820rbba54, 64f7055, alternatives, civic, crack, download, ecu, honda, kpro, matsushita, read, rom
