350-550whp B-series turbo guys, What Crank pulley???
Old Dec 14, 2007 | 09:10 PM
b20vtech's Avatar
Default 350-550whp B-series turbo guys, What Crank pulley???
just as the title states.... any OEM crank pulley users here?
Old Dec 14, 2007 | 09:18 PM
CoreyR's Avatar
Default Re: 350-550whp B-series turbo guys, What Crank pulley??? (b20vtech)
thats a large gap in power there. im running a stock pulley on a 350WHP GSR.
Old Dec 14, 2007 | 09:25 PM
96 GSR-T's Avatar
I am running a stock pulley too.
Old Dec 14, 2007 | 10:22 PM
blinx9900's Avatar
Default Re: (96 GSR-T)
350whp b16 here stock crank pulley.
Old Dec 14, 2007 | 10:29 PM
b20vtech's Avatar
Default Re: 350-550whp B-series turbo guys, What Crank pulley??? (CoreyR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CoreyR &raquo;</TD></TR><TR><TD CLASS="quote">thats a large gap in power there. </TD></TR></TABLE>
cause i also want to know what guys making over 350+ are using..
Old Dec 14, 2007 | 11:33 PM
mighty137's Avatar
Stock here as well....400hp.. Although an ATI would be nice..
Old Dec 15, 2007 | 03:06 AM
The sweed's Avatar
600hp 84,5mm b16 10500rpm stock rebalanced pulley.
There are realy good brands out there but they are kind of expensive compered to the advatages and a OEM works. Put the money to good electronics insted..(ECU, boost controler, great tune etc) OEM works good just dont get a solid pulley.. I would like to refer to it as a harmonic balancer. A solid pice will evensualy kill your oilpump and might kill even your crank bearings.. If the pump goes it can kill the entire engine..
EDIT: Bad spelling
Old Dec 15, 2007 | 03:10 AM
LS AzZkIkr's Avatar
Default Re: 350-550whp B-series turbo guys, What Crank pulley??? (The sweed)
what about the single belt stock crank pulley? i dont know what its real name is but i have one and am going boost soon. i dont know if they are balanced or if they even can be.
Old Dec 15, 2007 | 03:37 AM
markaria's Avatar
fluidamper here for 3+ years without a problem
Old Dec 15, 2007 | 05:41 AM
morgan@synapse motorsport's Avatar
Default Re: 350-550whp B-series turbo guys, What Crank pulley??? (LS AzZkIkr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LS AzZkIkr &raquo;</TD></TR><TR><TD CLASS="quote">what about the single belt stock crank pulley? i dont know what its real name is but i have one and am going boost soon. i dont know if they are balanced or if they even can be. </TD></TR></TABLE>
i think you are talking about the n1 pulley, i would highly recommend not using those. they are oil pump killers.
oem pulley, 613whp
Old Dec 15, 2007 | 06:03 AM
qfast817's Avatar
Default Re: 350-550whp B-series turbo guys, What Crank pulley??? (mike@synapse motorsport)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by markaria &raquo;</TD></TR><TR><TD CLASS="quote">fluidamper here for 3+ years without a problem</TD></TR></TABLE>
same here
Old Dec 15, 2007 | 08:56 AM
95exdsmkilla's Avatar
Default Re: 350-550whp B-series turbo guys, What Crank pulley??? (qfast817)
stock pulley....
Old Dec 15, 2007 | 09:32 AM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike@synapse motorsport &raquo;</TD></TR><TR><TD CLASS="quote">i think you are talking about the n1 pulley, i would highly recommend not using those. they are oil pump killers.
oem pulley, 613whp</TD></TR></TABLE>
true story
Old Dec 15, 2007 | 09:46 AM
arc_55's Avatar
I remeber having an article at one time in my favorites in regards to crankshaft and hamonic balancers. They hooked up a electronic scope to one end of the crankshaft and simulated a very tiny tap at one end. They did this with the damper off and on and the wave pattern was tremendously different. Even though this was not torrsional vibration it still showed the differances of having a damper on and off, which convienced me. I bite my lip when i see poeple with non-dampened pulleys.
I would really like to see some tests done between a convenional rubber damper vs. silcone or fluid.
Old Dec 15, 2007 | 03:19 PM
turbohf's Avatar
Default Re: (arc_55)
392whp 9500rpms....stock B16A pulley...
Old Dec 15, 2007 | 04:15 PM
gisserhatch's Avatar
530hp...stock pulley...ive lost it twice now but 3rd times a charm!
Old Dec 15, 2007 | 04:57 PM
wade's Avatar
Default Re: (gisserhatch)
ls1
Old Dec 15, 2007 | 05:07 PM
fmfkid250's Avatar
620whp OEM integra
Old Dec 15, 2007 | 06:35 PM
b20vtech's Avatar
good i will be using OEM...
Old Dec 15, 2007 | 07:50 PM
Jared's Avatar
a new oem works well with NO chips or damage but most of them arent like that. save yourself the headache and get the ATI
Old Dec 15, 2007 | 08:25 PM
Astig's Avatar
Default Re: (Jared)
501 whp
ATI
Old Dec 15, 2007 | 09:07 PM
tannerLSt's Avatar
ME LOVE U LONG TIME
so how bad is it if they have lil chips in the oem crank pulley?
Old Dec 16, 2007 | 07:14 AM
fmfkid250's Avatar
Default Re: (tannerLSt)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerLSt &raquo;</TD></TR><TR><TD CLASS="quote">so how bad is it if they have lil chips in the oem crank pulley?</TD></TR></TABLE>
I wouldent rock one on my built motor thats for sure.
Old Dec 16, 2007 | 08:02 AM
CRVRX's Avatar
Default Re: (fmfkid250)
OEM Type R, Good to 11,000rpms and runs the AC and PS.
Old Dec 16, 2007 | 08:16 AM
kermit97's Avatar
stock gsr is good for now unless u go more power then get ATI.
