Best way to remove "Civic DX" sticker...
Old Dec 14, 2007 | 02:04 PM
JKov240's Avatar
Default Best way to remove "Civic DX" sticker...
I'm not too sure of the best route I should take to remove this. I was thinking of warming it up with a heat gun and picking it off, I've eliminated the idea of scraping with a razor blade ...any ideas?
I'm not too sure if it'll leave an outline of the sticker either...
Old Dec 14, 2007 | 02:09 PM
SuperSonikBluEK's Avatar
Default Re: Best way to remove "Civic DX" sticker... (JKov240)
i took off my decals with a heat gun...worked pretty good
Old Dec 14, 2007 | 02:12 PM
JKov240's Avatar
Default Re: Best way to remove "Civic DX" sticker... (SuperSonikBluEK)
Did you just stay on it till they got soft and then pick them off?
Any outline left over?
Old Dec 14, 2007 | 02:21 PM
Budget Racer's Avatar
If it really is a sticker then try 3M adhesive remover. That shiZ will kill any sticker and sticker poop left behind. I removed pinstripes with that stuff and you couldn't tell I did anything it was so clean. didn't hurt the paint, but rinsed with water to be safe. Try Home Depot for the stuff if theres one by you.
Good luck!!
Old Dec 14, 2007 | 02:50 PM
Ej Girl's Avatar
i used a razor and windex....but be careful....
Old Dec 14, 2007 | 02:53 PM
Filippo's Avatar
Default Re: Best way to remove "Civic DX" sticker... (Ej Girl)
heat gun works very well! try using a degreaser to remove any residue.. shouldnt leave an imprint (depending on how much sun damage on the paint)
Old Dec 14, 2007 | 03:00 PM
blk92_d16's Avatar
When you hit about Mach II, it'll slide right off...oh d@mn, this isn't the F-16 forums!
Old Dec 14, 2007 | 03:09 PM
jasony0630's Avatar
76.26.106.124
goo gone...
Old Dec 14, 2007 | 03:13 PM
spintboy's Avatar
i removed my dohc vtec sticker off with a blow dryer and my finger nail.
came off great but left some stickers mark. its okie though, got it off with some goo gone easily.
Old Dec 14, 2007 | 03:16 PM
Default Re: (spintboy)
Listen. Say it with me... (3M ADHESIVE REMOVER) Trsut me. No heated paint needed. Maybe a plastic scraper to start the peel. That stuff will come off clean Bro. No sticker marks!!!!!!!!!!!!
Old Dec 14, 2007 | 03:19 PM
JustHere4ADay's Avatar
WHEEL Slayer
Default Re: (jasony0630)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jasony0630 &raquo;</TD></TR><TR><TD CLASS="quote">goo gone...</TD></TR></TABLE>
Old Dec 14, 2007 | 07:30 PM
1988_96hb's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Budget Racer &raquo;</TD></TR><TR><TD CLASS="quote">3M adhesive remover</TD></TR></TABLE>
X2
Old Dec 14, 2007 | 07:38 PM
Turbo EG4's Avatar
From: Ghost riding my grandmamas whip YEP, Los Angeles Cali
Default Re: Best way to remove "Civic DX" sticker... (1988_96hb)
just keep it looks clean
Old Dec 14, 2007 | 09:12 PM
NOFX's Avatar
H-T White Ops
The easiest way that I usually use (I remove lots of emblems for lots of cars) is to heat it with a heat gun (or hair dryer) and peel as much off as possible. Then use an adhesive remover such as Goo Gone on a cotton cloth to remove the rest.
Old Dec 14, 2007 | 10:10 PM
JKov240's Avatar
Default Re: Best way to remove "Civic DX" sticker... (Turbo EG4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Turbo EG4 &raquo;</TD></TR><TR><TD CLASS="quote"> just keep it looks clean </TD></TR></TABLE>
I'm just not really feeling it with the emblems blacked out
I'll for sure try the heat gun and see how it goes from there
Old Dec 14, 2007 | 10:56 PM
mastakmk's Avatar
goo gone x2. and the other stuff in the lil can.. works even better.. some other... oh.. goof off. there ya are.
Old Dec 14, 2007 | 10:59 PM
ferio252's Avatar
don't remove it ;( the DX is a badge of honor. wear it proudly.
Old Dec 15, 2007 | 12:41 AM
EGwhat!!!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuperSonikBluEK &raquo;</TD></TR><TR><TD CLASS="quote">i took off my decals with a heat gun...worked pretty good </TD></TR></TABLE>
x2
Old Dec 15, 2007 | 06:28 AM
95dxsir2's Avatar
Default Re: Best way to remove "Civic DX" sticker... (ferio252)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ferio252 &raquo;</TD></TR><TR><TD CLASS="quote">the DX is a badge of honor. wear it proudly.</TD></TR></TABLE>
Hell yeah, gotta love my dx **** box!!!
Old Dec 15, 2007 | 11:23 AM
mastakmk's Avatar
Default Re: Best way to remove "Civic DX" sticker... (95dxsir2)
looks a lot cleaner without the dx. i took it off my ek.. it wasn't a sticker tho it was an actual plastic badge. civic and dx at the bottom.
Old Dec 15, 2007 | 11:38 AM
NOFX's Avatar
H-T White Ops
I took my emblems off... just to put more on.
Old Dec 15, 2007 | 11:54 AM
EM1ly's Avatar
Default Re: (NOFX)
goo gone. it's cheap and works.
Old Dec 15, 2007 | 11:55 AM
ShortyzKustomz's Avatar
Get an Eraser wheel, sometimes called Pinstripe Removal Wheel, Goes on a rotary tool but can be used in a drill, Cleans all stickers and adhesives without hurting paint, I tried heat and removers before I I found about these wheels, 8-11 bucks at any auto body place, So quick and easy and last a while too, I use them everyday at work, It will even take off side moulding adhesives, Give it a try!
Old Dec 17, 2007 | 09:08 AM
Default Re: (ShortyzKustomz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1988_96hb &raquo;</TD></TR><TR><TD CLASS="quote">
X2</TD></TR></TABLE>
This guy knows whats up.
I never needed a heat gun, and I've tried goo gone and it's ok, but the 3m remover cleans so good without even trying. And your paint is safe.
Yalls shoud try it.
Old Dec 17, 2007 | 09:50 AM
fireant's Avatar
Default Re: (Budget Racer)
heat gun to peel it off, goo gone or wd40 to get rid of the poo left behind... then WAX THE AREA!!!
90civicstdgold
Apr 12, 2010 01:39 PM
donut.
Aug 27, 2005 11:41 AM
sacrilege
May 1, 2003 12:40 PM
GReddy SI
13
Dec 10, 2002 11:04 PM
Dr. Thodt
Apr 28, 2002 10:39 PM
