94 accord starting problem!!
Old Dec 14, 2007 | 01:24 PM
killersoundz's Avatar
Default 94 accord starting problem!!
My 94 accord ex doesn't even try to crank. Thought it was the starter but that is not likely. For some reason the solenoid is getting power to the big wire all the time, even when the key isn't in the start position. We're thinking it might be the ignition switch. Anyone have any idea what is going on with this?
Are there any starter relays or any other thing that can go bad unexpectedly that will cause the solenoid to not even engage?
I left my headlights on and came out to find my battery dead of course. Tried jumping it 3 times, decided the battery was shot and got a new one. Nope wasn't the battery. For some reason the anti theft light on the steering column blinks now. Never blinked once since I got the car until I came out and tried to jump it after it wouldn't start from having a dead battery.
!!! This is really frustrating thank you.
Old Dec 14, 2007 | 01:40 PM
cb7tuned's Avatar
Default Re: 94 accord starting problem!! (killersoundz)
could be a bad alternator. you could get it checked out for free at autozone.
Old Dec 14, 2007 | 01:54 PM
chicows18's Avatar
If the anti-theft light is blinking, that usually means that its armed and wouldnt that cause the car not to start? Im not too familiar with the accords, but on newer hondas and acuras thats what the immobilizer system does. It blinks when armed and someone is trying to start with wrong key or ecu not programmed for the key you are trying to use. Seems like an electrical problem too.
wizzbangca
Nov 17, 2013 07:11 AM
killersoundz
Dec 15, 2007 10:51 AM
hondakevin21
Jan 25, 2007 06:12 PM
liem43
Mar 7, 2004 09:41 PM
