85mm headgasket on a 84.5mm motor?
Old Dec 14, 2007 | 11:03 AM
.adam.'s Avatar
Default 85mm headgasket on a 84.5mm motor?
is anyone on here running an 85mm golden eagle headgasket on a 84.5mm motor. the place where i buy my parts from only stocks 84mm and 85mm, no 84.5mm and the owner said i'll be fine with an 85 and thats what everybody else gets, but i dont know if hes just trying to make a buck or if its true......
Old Dec 14, 2007 | 12:18 PM
Turbo-charged's Avatar
Default Re: 85mm headgasket on a 84.5mm motor? (.adam.)
ive run .5mm over headgasket numerous times with out any problems.
Old Dec 14, 2007 | 06:09 PM
88crxvtec's Avatar
ben at importparts.com gets 84.5 mm headgaskets.
Old Dec 14, 2007 | 06:25 PM
yakuza's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .adam. &raquo;</TD></TR><TR><TD CLASS="quote">is anyone on here running an 85mm golden eagle headgasket on a 84.5mm motor. the place where i buy my parts from only stocks 84mm and 85mm, no 84.5mm and the owner said i'll be fine with an 85 and thats what everybody else gets, but i dont know if hes just trying to make a buck or if its true......
https://honda-tech.com/zerothread?id=2125674 &lt;---
Old Dec 14, 2007 | 06:32 PM
Jared's Avatar
you'll be ok, i run an 85mm cometic on an 84.5mm bore. its only a difference of .020"
Old Dec 14, 2007 | 08:37 PM
.adam.'s Avatar
well right now i have a new golden eagle 84mm but the bore is a HAIR smaller than my sleeve bore......should i run it anyways is that not a good idea
Old Dec 15, 2007 | 06:02 AM
rmcdaniels's Avatar
I've run .5mm over without problems, currently running 86mm on an 85.55mm bore.
Old Dec 16, 2007 | 01:04 PM
.adam.'s Avatar
would running a 84mm head gasket on a 84.5mm bore be a bad idea, the bore diameter of the headgasket is few thou smaller than the sleeve bore.
Old Dec 16, 2007 | 01:20 PM
EARLdaSQUIRREL's Avatar
official honda whore
Default Re: (.adam.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by .adam. &raquo;</TD></TR><TR><TD CLASS="quote">would running a 84mm head gasket on a 84.5mm bore be a bad idea, the bore diameter of the headgasket is few thou smaller than the sleeve bore.</TD></TR></TABLE>
thats fine
ive always ran 81mm gaskets with 81.5mm bore
Old Dec 16, 2007 | 05:58 PM
.adam.'s Avatar
well i think that 81mm head gaskets still have a slightly bigger bore than 81.5 but i could be wrong
Old Dec 16, 2007 | 07:49 PM
JDM_SOHC's Avatar
had to chime in on this one... but from what i was taught, ur H.G. should always be at least .5mm over ur bore.. I learned this from one of Ed Bergenholtz's mechanics.. An since Ed was out there breaking track records I figured that was always the right way, im suprised using a gasket thats smaller than ur bore works out good, I figured it would mess with ur compression or something...
Old Dec 16, 2007 | 10:21 PM
civic_sc's Avatar
Default Re: 85mm headgasket on a 84.5mm motor? (Turbo-charged)
do it all the time .....bigger it s ok ..smaller is not good
billyinse
35
Jan 20, 2007 11:46 AM
honda_tuner10
Oct 14, 2006 10:49 PM
97grnrs
Aug 22, 2006 05:53 PM
93DXEGG
10
Jan 7, 2006 04:42 PM
hks3630
Dec 8, 2003 06:29 PM
