is the hub centric ring for honda civics really 56.1?
Old Dec 14, 2007 | 09:11 AM
civicnoob's Avatar
Default is the hub centric ring for honda civics really 56.1?
my hub centric ring didn't fit snug against the rotor(this is with the ring taken off of the wheel). so i had to grind down the hub to make it fit.
isn't it suppose to fit snug against the rotor?
i got a new spindle and i had to do the same thing to this one.
95 honda civic dx
Modified by civicnoob at 10:39 AM 12/14/2007
Modified by civicnoob at 10:42 AM 12/14/2007
Old Feb 15, 2008 | 05:04 PM
90JPRCRX's Avatar
Smells like Tuna
Default Re: is the hub centric ring for honda civics really 56.1? (civicnoob)
Old Feb 16, 2008 | 08:58 AM
nsxtasy's Avatar
H-T Order of Merit
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicnoob &raquo;</TD></TR><TR><TD CLASS="quote">my hub centric ring didn't fit snug against the rotor(this is with the ring taken off of the wheel). so i had to grind down the hub to make it fit.
isn't it suppose to fit snug against the rotor?</TD></TR></TABLE>
No.
The outside edge of the ring is supposed to fit snug against the center bore of the wheel (that's the big hole in the middle of the wheel).
The inside edge of the ring is supposed to fit with a slight gap around the hub (the part of the hub that sticks out around the axle nut). Not the brake rotor.
Old Feb 18, 2008 | 03:12 PM
BrakeExpert's Avatar
Default Re: is the hub centric ring for honda civics really 56.1? (nsxtasy)
The center is 56.15mm. Whoever made those rings tapered em too much if you ask me.
The centerbore of the rotor (the lower part of the hub) is 61.5mm for DX civics, and 64.1mm for Civics with 10.3" brakes (like EX models)
rich9933
Honda Fit
Mar 7, 2014 03:15 PM
good apollo
Mar 9, 2008 06:08 PM
kanthee
Honda Fit
Nov 13, 2006 09:27 AM
HUBB
29
Sep 21, 2003 06:51 PM
mickey513
Jul 26, 2002 07:19 AM
